While transporting my Ridgid tile saw, I mishandled it and broke the plastic housing where it meets the metal stand. Im having trouble locating the part. The saw model is two years old.
Ridgid7" Job Site Tile Saw with Laser. ... Heavy Duty Arm - prevents flexing while keeping the blade aligned; Guard Baffle - reduces air turbulence to help keep water ...
7" BRIDGE. TILE SAW. WITH STAND. Owner's Manual & Safety Instructions. Save This Manual .... that has an outlet that looks like the one illustrated above ... Use saw-blade guard and spreader for every .... arms and shoulders. To reduce the.
parts. Nonslip footwear is recommended. Wear protective hair covering to contain long hair. 11. ALWAYS USE ... an outlet that looks like the one illustrated above in Figure A:... For Your Own Safety Read Instruction Manual Before Operating Saw. 1. Wear eye ..... Connect the clear water Hose from under the arm of the Motor ...
The Ridigid WTS2000L Tile saw is actually built by Chervron North America and not directly supported by Ridgid. You can reach them at 866-974-3443. This is a direct line for WTS2000L service. Hope this helps.Positive feedback always welcome :)
"In my opinion" I would stay away from the Ridgid tile saw. We had one come into our shop for repair of a burned out motor and could not get parts for it. The saw, at that time, wasn't made by Ridgid, it only carried the Ridgid name. I'm not familiar with the Dewalt tile saw enough to give you an opinion on it. If I were in the market for a tile saw, I'd get one by MK Diamond, they specialize in tile, stone, etc. cutting and make the best tile cutters I've used and worked on. They're priced towards the high end but are of contractor or industrial quality so will last a long time. If they do need repairs they're easy to get parts for that are fairly priced.
Look for adjustment for tensioning belt. The motor is probably mounted on a sliding bracket arrangement which came loose during transport slackening the belt.
Its either the speed of the blade ( mine came with its speed at half rate), or its the crappy blade they give you with the saw. If a cut is bowing your blade is having a tough time with material. This often happens with tough porcelain tiles and not using a porcelain blade.
You usually don't install gfi's at the load (saw) but instead at a socket where the plug is inserted. If you use an extension cord, change the socket end to a metal 'handy' outlet box and install a local type gfi there. Wire the black wire to the brass screw, the white wire to the silver screw, and green wire to the green screw. Make sure that none of the wire strands are left loose to short out on something. They are available in any hardware store or home center. Hope this helps!
