I've played with every button, surfed every sub menu, and read all the instructions. I can can't get the camera to use the memory card. It only records using internal memory.Is there some secret to switching which memory it is using?
SOURCE: camera won't recognize the memory card
try formatting the card. see page 65 of the manual.get the manual here http://www.dxgusa.com/downloads
SOURCE: Sony DCR SX40: internal memory format error
You may have to try some video recovery software, here are some for your options. Both programs can also recover photos and music.
video photo recovery program (for Windows OS)
Mac video photo recovery program (for Mac OS X)
First of all you need to install the program on your computer (choose the right version based on the operation system you are running), then connect your camcorder (memory card or HDD) to the computer and start to recover your deleted videos.
One More Tip: Your should act as soon as possible and before the deleted videos are recovered, better not take more videos in case overwritten situation will happen.
SOURCE: my camera says "memory full" yet there is nothing
hi.please format your camera with computer.your camera have virus.thanks
Format
Internal memory format : Remove the SD memory card to format the internal memory.
SD memory card format : Insert the SD memory card to format the SD memory card.
All the files in the memory are deleted by the [FORMAT] function.
Before formatting the memory, it is advisable to copy important data onto other media as back-up
e.g. floppy disks, hard disks, CD etc.
1. Turn the camera power on.
2. Select the PLAY mode by rotating the mode dial.
3. Do not turn the LCD monitor off.
4. Press the MENU button to display the menu on the LCD
monitor.
5. Press the UP( )/ DOWN( ) button and select [DELETE].
6. Press the SET( ) button and the sub menu will display.
7. Select [FORMAT] by pressing the UP( )/DOWN( ) button
and press the SET( ) button
8. Select [NO] or [YES] and press the SET( ) button.
[Selecting NO] : The image will be displayed on the
LCD monitor.
[Selecting YES] : A [PLEASE WAIT!] message is
displayed and all of images are
deleted.
Link to manual:
http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=2702&prd_mdl_cd=EC-D201ZSBA/E1&prd_mdl_name=DIGIMAX%20201&srchword=digimax%20201
