When I turn on the radio or insert a CD almost immediately stereo turns itself off and message F-61 appears. It has worked fine for past 2-3 years. Model SA AK640 panasonic stereo system
Very complex problem, could be your steering wheel controls, ECM sending false digital signals or just a bad radio (internal contacts bad) or maybe someone (a child usually) has inserted a penny or such into the disc opening. Yes it has happened before. Replacing the stereo with an aftermarket unit might be the best bet on pricing. Good Luck!
Please try this!! You may need a soft or hard reset. Here's some reading and instructions. Please use this first! resetting your scanner 1. Turn off your scanner, and then turn it on again.
2. Insert a pointed object into the reset hole on the back of the scanner. Then, gently press and release the reset button. Pressing reset does not clear the scanner's working memory or the V-Scanner folders.
If this doesn't work here's step two! CAUTION. THIS WILL ERASE EVERYTHING, but it MAY Fix the Problem!! Initializing your scanner clears all information stored in your scanner's working memory. Initialize your scanner only when you are sure it is not working properly. V-Scanner memory is not affected when you initialize the scanner.
1. Turn off the scanner, and turn it on again. First, the DSP boot version, and then Welcome To Digital Trunking appears.
2. Press 0. The following messages appear on the display: System Tests
Select Test Exits if no Key Press
3. Press 1. The following messages appear on the display: Factory Init Erase Memory ENTER if Yes CL to EXIT
4. Press ENT. The following messages appear on the display: Initializing Clr Main Mem V-Scan is OK Please Wait
5. Do not turn off your scanner until the initialization is complete. When the initialization is complete, M000 and Bank 0 Ch 00 appear on the display.
sounds like a short or loosening wire somewhere - have any "after- market" accessories been added ??? new stereo or amp ?? check these item and there wiring if so. It could also be the ignition switch itself......unfortunately - you may have to wait for a permanent failure to find the cause
