Hotpoint Ultima WF865 Front Load Washer Logo
Posted on Jan 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hotpoint washing machine - WF865 showing F-08 fault
I have a Hotpoint WF865 which has just come up with F-08 fault
Was washing 2 bath towels on long cycle at 30c. When opened door towels were very wet and quite warm but no water laying in machine.
Please help got school uniform to wash!!
Lucy
Anonymous
Level 2:
  • Expert 104 Answers
  • Posted on Jan 28, 2010
Anonymous
Expert
Level 2:
Answers
104
Questions
Helped
17969
Points
163
F08: Heater control or NTC (Thermistor) temperature sensor problem.
Hotpoint ultimate wd860
First all all unplug it for 2 mins to clear error code. That error relates to heater or pcb fault. Check the wires on the heater then pcb make sure they are tight. Give the relays a tap on the pcb it could be stuck
Could you tell me the load capacity to the hotpoint wma64 please
Maximum load 5.5Kg
Wash Load Examples:
Two examples
of maximum
wash loads for
different types
of fabric.
COTTON
2 Bath Towels
5 Shirts
6 Blouses
1 pair of
Pyjamas
4 items of
Underwear
= 5.5kg
SYNTHETIC
2 Children's
Dresses
4 Shirts
4 Blouses
1 pair of
Pyjamas
4 items of
Underwear
= 3kg
5helpful
Hotpoint Ultima Super Silent WF865. I'm getting error code F04 there's water in the machine and it's stopped.
Error code F04 indicates pressure switch jammed on empty.
Remove the lower rear panel of washer.
Remove the large black hose fastened to bottom of drum.
Remove and clean the plastic filter inside hose.
Remove the hose onto the pump, and check for blockage or obstruction here.
This should clear the fault
please leave feedback for my solution.
Thanks.
11helpful
Washing machine stuck in test mode hotpoint wf865
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Your machine should now work. hope this helps.
11helpful
Test mode
press start once
then press start again now hold on/off and cancel together for a few secs should no say d/off or something should work now
Hotpoint WF865 Child Lock Button Stuck 'On'
you should be able to turn it off by holding it in for a while longer,5-10 seconds, unless the circuit board is at fault.
2helpful
2answers
i have a wf 860p hotpoint washing machine and it has come up with an error code of f 08 can you tell what this error is and how i can fix it.
many thanks
lynette
Fault
h20 means it's not getting any water or not filling fast enough. check your water pressure.
7helpful
Hotpoint wf865 problem
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Pl rate me nice if this solution helped!
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
