Question about Westinghouse SK-32H240S Television
Tv does not stay on, screen goes black
We plugged the tv in pushed the power button and the blue light turns on. the screen comes on with the w symbol and then it goes black. it then comes on again with the channel number and no signal andthen goes black again. whats wrong?
    Sergeant:
    Champion:
  • Westinghouse Expert
  • 279 Answers
Checked all connection given properly checked your cable connection some time cable connection not proper than also its display no signal
Posted on Jan 23, 2010
TV wont turn on sometimes. push the on button, light turns from red to blue but no display or sound. If I disconnect the power cord for 15-20 min and plug it back in to the tv it will turn on and stay
My Samsung started doing that and it got worst and worst. Searched the web and find answer. It was the high voltage circuit. All TVs now are like computer and it check for 390 to 400 volts and if it is below, the TV will not turn on. Good thing the Samsung has only one capacitor showing the high voltage circuit. Measure the voltage was 381 volts. The capacitor was rated at 100 uf at 450 volts. From some old TV and power supply, got two capacitors rated 150 uf and 220 uf both at 400 volts. Had to connect them in parallel and took out the old capacitor. Now, my TV works fine.
Nov 03, 2017 | LG 42LG30 42 in. LCD HDTV
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Screen goes black nafter start up. What can I do?
You probably have some bad buffer boards as well as a bad Y-main bd and or a bad X-Main bd. Have a trained samsung tech troubleshoot the set.
Jul 02, 2009 | Samsung HP-S4253 Television
Black Screen, Not turning on but charges?
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
Feb 06, 2008 | Creative Labs ZEN V Plus MP3 Player
My Mp3 player has a black screen but blue backlight for buttons is on
yes i would take it back whilst it on warranty and not mess with it or you will lose your warranty as it is a internal fault
Feb 06, 2008 | Creative Labs Zen Touch MP3 Player
Televison & Video Logo
815 people viewed this question
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
