Question about Aqua -Vu Perch Underwater Camera with 100-Ft. Cord GPS Receiver
Aqua vu camera - the male plug from the camera pushed out the prongs on the female half of the plug in. The wires are red black. blue and yellow. On the backside of the female plug there are numbers (1-4) - which color goes with each number
Posted by syaeg on
1 Related Answer
travelbobgau
  • 6 Answers
SOURCE: aqua vu underwater camera
i figgured out how to fix it. i was having the same prob. so i cut the male conector part off the the camera cord and cut like 4" of the black cord part off to expose the wires. there will be 4 colored wires and 1 bare wire cut the bare wire off as close as you can to where you stripped off the black part, then expose the top inch of each color wire. OK now open up the back of the monitor, take the black female connector off you dont need it. you will see a 4 prong female connector part inside cut that off too, then conect the wires black - black / yellow - white / red - orange (i think it was orange) / blue - green . it sounds kinda complicated, but really easy, and now it works great! make sure you use electrical tape or something over bare wires
Posted on Jan 25, 2011
How to wire a plug
In USA, Either the male or female plug connector would be wired the same. Black is hot wire and would connect to the BRASS colored round head screw ( Smallest flat prong or slot ). White is the neutral wire and would connect to the SILVER colored round head screw ( Largest flat prong or slot ). Green is the ground wire and would connect to the GREEN screw ( ONLY HEX shaped screw ). 1) FOR YOUR LIFE SAFETY, ALWAYS USE 3-WIIRE PLUGS WHEN REPAIRING 3-WIRE EXTENSION CORDS! 2) Check the male plug connector. It should have two flat and one rounded prong. The rounded prong is the ground wire connection. If the ground prong is missing, replace the plug. 3) Inspect the outer cover for damage. 4) Do not use cords with damaged outer covers. Taping over the damage is not an adequate repair, for safety, replace the cord.
Apr 04, 2014 | Woods Industries 12/3X100FT Yellow Jacket...
We are experiancing probems with our agua view. The light comes on on the moniter but there is no video coming through. Is there a fix for this issue
Jan 16, 2011 | Aqua -Vu Perch Underwater Camera with...
I have a 3 prung male plug, and a 4 prung female plug. Can I switch the 3 male plug to a 4 male plug?
Hi, and yes you can, its done all of the time. You want to change the plug on the wall, not the cord. That is the way it is done. Very simple. Turn off breaker to the 4- prong. Go to any hardware store such as home depot and get the 3 prong 220 volt female plug, both are the same volts, just made for different cords is all. The male is on the cord. On the 4 prong female plug thats on the wall, just loosen all 4 screws. 2- wires are hot, either black in color, a black with a piece of white tape on it is the neutral, and a bare ground which is much smaller. When installing the 3 prong female, you will use all 4 wire to. 2- hot, ! neutral, and a screw for the small bare ground. There will be a drawing on how to connect the wires with the new plug if you are not sure. Normally, there are 3 black wires, 2 hot , 1 neutral. Some times there may be 2 blacks and 1 red. A black and red will be hot.I am sure they will all be black. The plug is marked on it. It will have L-1, L-2, N, and Ground. When you remove the 4 prong female, it will be marked the same. Be sure the power is off! L-1 and L-2 are hot, and the 3rd is N or neutral. Then the small ground. Very, very, simple to change and to know which is which. The terminals on the plug are colored also. The 2 that are copper colored are for the hot wires. The brass or silver is the neutral. And you will see the ground screw. I hope I haven't confused you, it is very easy. Just when removing the wires to the old plug on the wall, which should be a 4-prong female, the 2 wires on the right and left side of the plug are going to be the 2 hot wires. The other large black is the neutral goes to top or bottom, its marked like I said with a N. and a small bare ground. Always change the plug on the wall to fit the dryer from 3 to 4, or 4 to 3. They are both 30 amp plugs, 220 volt. Very easy, you can do this!! Please rate me on my help to you.
Sincerely,
Shastalaker7
Jan 04, 2011 | Whirlpool LEB6300 Electric Dryer
How do I make the connections from the Red - White - Yellow RCA Male plugs of the camera to a USB adapter Red - Blue - Green RCA Female to download to a computer? Stumped.
Hello, for the descriptions of the colors (red. green, and blue) of the USB video adapter, what you have is a "component video input" also called YUV in which you can only send color difference signals from a device that has the same kind of output, like a DVD player. So, you cannot plug your cam cable directly to them.
Maybe your USB adapter has another input or dongle in which the colors of the RCA jacks are the same as you have in your camcorder. Red: right Audio, Black: left Audio and Yellow: composite video.
Send me back more info of your adapter, like make and model, maybe I can see the specs and add more help in this matter.
Good luck
Dec 09, 2010 | Sharp VL-E610U Camcorder
Wiring diagram for sky+hd telephone plug
If the plug is the traditional 3 x prong with a plastic guide thingy. This is known as a 604 male phone plug.
Wires in cable should be
a) green, red, black and yellow ( or just red and green)
red goes on 2
Green goes on 6
Black goes on 1
yellow goes onto 5
Good luck
Laurie G
(both numbers imbedded in the plastic mould of plug
If it is the female 610 socket, wires go same as above
Jun 05, 2010 | Lands Phones
I have an aqua vu scout and it has good battery and connection but no picture
mike if you are still having this problem, i figgured out how to fix it. i was having the same prob. so i cut the male conector part off the the camera cord and cut like 4" of the black cord part off to expose the wires. there will be 4 colored wires and 1 bare wire cut the bare wire off as close as you can to where you stripped off the black part, then expose the top inch of each color wire. OK now open up the back of the monitor, take the black female connector off you dont need it. you will see a 4 prong female connector part inside cut that off too, then conect the wires black - black / yellow - white / red - orange (i think it was orange) / blue - green . it sounds kinda complicated, but really easy, and now it works great! make sure you use electrical tape or something over bare wires
Dec 23, 2009 | Aqua GPS
VHS to Easy capture to computer
The plugs you speak of are called RCA plugs, (Male side has an outside ring with "slots" around the edge, and a pin in the center. Female side has a short round "riser" with a hole in it). You need just standard Audio/Video hookup cables, available at any electronics store.. Walmart/Target/Kmart has them in the TV section. They get plugged into the Audio (Red & White) OUT of the VCR, into the Audio IN (Red & White) of the Easy Capture. The Yellow lead is for Video In/Out between the VCR and Easy Capture. The black is probably the S-Video connector, (round, has very small square hole, surronded by 4, 5, or 7 tiny pin holes) that can be also used to connect video/audio between VCR(if so equipped) and Easy Capture. Get a set of audio/video dubbing cables (abt $10 usually), connect Red to Red, White to White, Yellow to Yellow. Plug the Easy Capture USB cable into your computer (most likely), start the capture program. Start your vcr, hit Play. You should see your vcr tape playing on the computer screen.
Aug 18, 2009 | Televison & Video
I am converting a 3 prong dryer to a 4 prong plug. The wires inside the dryer are black/yellow, white and blue. The wires on the plug are white, black, red and green. I am assuming the green is the ground...
on plug white is neutral, black is power , red is power, green is ground. black/yellow and blue are power and white is always neutral ie. (white to white) black to black/yellow, blue to red. green to grounding screw on machine
Jan 04, 2009 | Estate TEDX640JQ Electric Dryer
Aqua vu underwater camera
Aug 09, 2008 | Aqua -Vu Perch Underwater Camera with...
Need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Feb 17, 2008 | Cameras
GPS Logo
210 people viewed this question
Top Aqua GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you an Aqua GPS Expert? Answer questions, earn points and help others
