My pro-2096 radio shack digital trunking mobile/base scanner does not display any letters or numbers. the light does come on only.
If all else fails, you can RESET or INITIALIZE the scanner to bring it back to normal operation.
To RESET:
- Power the scanner OFF
- Power the scanner back ON
- Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner
- Gently press and then release the RESET button inside the hole.
NOTE: RESET will NOT erase the data that you've programmed into the scanner.
If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
- Press 0 after the scanner completes its boot routine
- Press 1 after the menu appears
- Press ENT
DO
NOT power the scanner OFF until the INITIALIZE process is complete
(M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure
will reset the scanner to original factory settings and erase all data
that you have programmed.
BillB
