Palm Treo 700wx Smartphone Logo
Posted on Jan 22, 2010
My screen is frozen - Palm Treo 700wx Smartphone
Anonymous
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Jan 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
3723
Points
42
Take it to the service
2answers
How to Fix Kindle Paperwhite Frozen on Lock Screen?
Oops, are you troubleshooting the Kindle Paperwhite Screen Frozen problem? Have you tried all the possible ways to solve this difficulty? Not to worry, if the steps you perform don't work, we are here with some fully searched solutions that will help you to overcome Kindle Paperwhite Frozen on Lock Screen. Follow the guidelines step by step to get out of Kindle Paperwhite Screen Frozen matter easily on your own.
Steps To Solve Kindle Paperwhite Screen Frozen In Minutes
Charge The Kindle
A very common reason that leads to Kindle Paperwhite Screen frozen is the lower battery. It can be possible that you are facing screen stuck issues as of the empty or uncharged battery.
So, to let your device work properly you have to charge it first. Hopefully, charging your device will help you to overcome Screen frozen on Kindle.
Uninstall Corrupted File
If you have downloaded a wrong or corrupted file then you are definitely going through with Kindle paperwhite frozen on lock screen as well as scattering issues with Kindle.
Kindly uninstall the corrupted file as quickly as you can do, otherwise, it will cause damage to your device.
Screen freeze
Press and hold the power button for 5 seconds and it shoild shut off.
Nikon l20 the screen froze
Take the batteries out of it let it sit for about 5 minutes and then put them back in
1helpful
Screen is frozen on with no picture and no sound. Does not respond to either remote control or manual controls. The tv did work and then after a few minutes went frozen.
You need to move further south if it is frozen. It's cold up north :-)
If you've pulled the power from this tv (power cycled it) and it still has this problem ... frozen with no picture and no sound. How a screen can be frozen with no picture, I'm not sure. But it sounds like you are going to be on your way to the repair shop. Or to buy a new tv.
If I couldn't see and couldn't hear, how would I know you were even here?
15helpful
2answers
My gt-s5230 screen is frozen what can i do
MY SAMSUNG GT-S5230 TOUCH SCREEN IS FROZEN, WHAT DO I DO?
Oct 27, 2009 • Cell Phones
1helpful
Frozen Screen
Mine does this from time to time. I pull the SD map card, power it off, and hit the reset button while the unit is unplugged. These units are notorious for this. But then again, they're inexpensive. No receipt ... well, you're pretty much stuck with it. No receipt, no return or repair.
Samsung a707 frozen
Hi friend,
I think first you should check whether the phone or the screen frozen, or both of them are frozen, if the phone is frozen,you may try to turn it off for about ten minutes then turn it on, if it still cannot work, you may try to pull the battery out and then restore factory setting if it needs.If the screen is frozen,it may because.....you can visit our website:
www.1010store.com. Hope this can help you!
26helpful
5answers
Garmin c330
You will need to reset the device.
1. On the silver faceplat, under the word "Garmin", there is a tab. Remove the silver-ish fram carefully by pulling on the tab with your nail then by the sides.
2. once removed, press the reset button.
3. Once reset, the unit should work properly.
Top Palm Cell Phones Experts
ExpressFiX
ExpressFiX
Mohammad Abumuailek
Mohammad Abumuailek
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
