Question about Microsoft Xbox 360 Console
Disc door will not open
Disc door is broken,the game console will not read game disc .the words opening and closeing keep showing on the tv screen where it is not reading the game disc.
Posted by tayboo0193 on
James Bradburn
  • 299 Answers
The magnetic weight thats mounted on top of the dvd drive on the inside has came loose and jamming the door. Also it wont read the discs if this happens. I repair drive issues in PS3 and 360's with 99% success
Posted on Jan 23, 2010
Anonymous
    New Friend:
How will i make my xbox disc opener work
1helpful
Console does not read any discs and shows open tray in my xbox screen
Try to open and close the disc tray without a disc and turn it off. Turn it back on and open tray and insert disc. If it still has the problem look into a simple fix on this video.
The video is kinda grainy but it does what it needs. Let me know if you have any questions or need parts.
The xbox 360 elites keeps on saying open tray when trying to play
1, the disc may be dirty
2. the mian reason for this your xbox drive cannot read the disc , because the power of the lens is gone(not completely) ,
solution:
1. keep your disc inside the drive and switch off the console, again swith on try this 2 to 3 time
2. keep the console in vertical position or little slanding position(180 dg) make sure it does not fall
3. its better to buy hatddisc and load the game inside it , so that u lens life increased
4. change the entire drive
1helpful
2answers
I put the disc in and on my tv it says open tray and when I do that and close it it says reading then goes back to open tray.
Hi friend try this:
1) Restart your console.
2) Check for loose cables.
3) Pull out all the cables, and get them back in.
4) Take out the hard-drive, and put it back in. Repeat this 4 times.
if the problem still persists then you need to replace your disc drive.
Please vote for me.
1helpful
The xbox can't read the unscratched and clean discs
yeah, you can keep opening and closing it till it works or you can send it in to get it repaired. i tried every way possible to fix it, but i couldnt. something in the dvd drive has gone out and won't read discs the same anymore.
1helpful
I bought a gamecube online and it wont spin the disk
Sounds like you need the Gamecube sensor switch replaced. That is a small door device for detecting when the Gamecube DVD door or lid is closed allowing disc initiation to begin. When your Gamecube doesn't detect disk at all and simply continues the message: "Please insert a NINTENDO GAMECUBE DISC," this is the problem. You can test this by inserting a game disc, opening the Gamecube door, and then closing it. If the message "Please insert a NINTENDO GAMECUBE DISC" remains unchanged, and there is no spinning of the disk, then your GameCube lid closed door sensor is probably broken and should be replaced. You can search Google for Part GCPT032, or for GameCube Lid Closed Door Sensor.
An easy fix if you know how to open the Cube. It's cable simply plugs in, and it is held by one tiny screw.
5helpful
2answers
My 360 dose not read discs but it dose spin them
Disc Error :- I have the same error. You can do 4 things.
A) You have to keep turning it on and off. Here's how... Turn it on, then click open tray then close tray ( keep opening and closing tray about 10 times) then turn the console off. Then keep repeating process for about 15-20 minutes and eventually the game disc will show up. ( I have to do this every time)
B) Make sure that this is covered by Microsof't's RROD warranty. Then some how get teh red rings on this console and send it to Microsoft. (Note: I am not held responsible for your actions.)
C) This is a lens problem. So go out to a store and buy a DVD lens cleanser. It's a disc that cleans the lenses of the DVD or the XBOX.
D) Open it up and replace the lens (like the above guy said) (much harder and more costly).
Pls rate my solution if it did help thanks.
PS2 HELP WANTED!!!!!!!
my friend had the same problem what he had to do was keep opening and closing the disc tray untill the 'reading disc' shows up and stays up but he got really anoyed with doing this so he got a new one shortly after this the ps3 came out...
My xbox 360 doesn't play my games
it could be that u got **** like food in your x box360 open it up and clean it out put it back to gether and try it if this dose not work tell me at [email protected] ty
My 360 elite makes me open and close the disc tray
DVD Drive failure most common problem, this ranges from dirty disk error (DDE) message to inoperable drive door, skipping in movies, slow load time or no load or the call customer service errors 10, 11, and 12. To replace the drive it will have to be reflashed.
Xbox 360 door will not stay closed
take the faceplate off then open and close it,
also make sure there is nothing blocking the door and there are no other discs in the tray.
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Ekse
Joseph Murphy
Joseph Murphy
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
