Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
Powersteamer 1697, 8804 series, Smartmix will not despense cleaning solution
Posted by nesledge on
Anonymous
    Problem Solver:
  • 12 Answers
There is usually a button or release lever by the handle that u sqeeze to release salution
Posted on Jan 27, 2010
How do you put the soultion in and how do you use it
Here is link to the users manual:
http://www.bissell.com/assets/0/132/134/228/14489708-7c37-4678-a90a-79e6825ef104.pdf
but real quick, heres the essentials:
Fill the SmartMix/formula tank
Lift the formula tank up and out of the machine base.
Fill the formula tank
by first unscrewing the cap
and insert. Always use genuine BISSELL formulas
to maximize cleaning and for the safety of your
machine. Fill formula up to the line and replace the
cap and insert. Place formula tank into the slot in the
back of the machine for a snug fit.
2b.
If using the BISSELL 3X Concentrated Fiber Cleansing
Formula: Add 3 capfuls of 3X Concentrated Fiber
Cleansing formula to the formula tank, and then fill
with warm water to the line.
Note: If bottle leaks, check for proper positioning
of red gromment and straw insert.
Good luck and thanks for using FIXYA
Please rate us if you are happy :)
Apr 06, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
Wont discharge shampoo!
Make sure there is liquid in both the Tank-in-Tank and the SmartMix Bottle and check for spray through the upholstery hose. If the hose does not spray please check the following:
- Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
- Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
- Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized, the cap will not make proper contact with the unit and the smart mix bottle will need to be replaced.
- Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
- Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. Bladder or SmartMix bottle may be empty or the valve may be blocked internally.
- Check if the small rounded window tabs on the top edge of the Floor Nozzle Window are locked in their mating slots on the base of the machine and not inadvertently lifting the tank up out of place.
Nov 23, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
My bissell wont release water or cleaner
Nov 05, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
What can i do if i dont have a soap despenser
With this unit, use a small shotglass of soap solution into the water container when you are filling it up. the soap will premix in the water there and be good for the system to continue using. Make sure that the dial is set on WATER ONLY so that you are not getting soapy water coming out of where the soap bottle should be.
Nov 04, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell Powersteamer will not eject cleaning solution what can I do to fix it?
Try these suggestions to get your machine working properly:
If these suggestions do not resolve your issue contact BISSELL Consumer Services for further assistance.
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Aug 02, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Does not spray the water and cleaning solution
If these suggestions do not solve the problem, have a technician at a local BISSELL Authorized Service Center inspect your machine.
To locate your nearest BISSELL Authorized Service Center, go to www.bissell.com. Click on the Customer Support tab near the top of the homepage and enter your zip code in the Service Center locator box to perform your search.
You can also locate a Service Center by phone, 24 hours a day, by calling 1-800-237-7691 and choosing option #1.
Jun 17, 2010 | Bissell 1699 ProHeat Clear View Upright...
Can not get smartmix knob and plunger to line up to put back together
Turn the plunger so that the flat edge is turned all the way to the right (clock wise) as far as it will go. Turn the dial on the cover to just water and it should line up. If the plunger is stuck in the cover pull it out and put it in the bottom part of the cleaner.
Feb 04, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
I THINK THE SMART MIX PISTON IS INSTALLEDS WRONG
it has the rubber seal and the container releases fluid when it depressed.... bipolar lol..
fill it with hot water and prime the machine.. don't use soap just try lear the lines.. always run hot water through your machine to clear the lines before storage.. and to maintain prime
Oct 16, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell Powersteamer 7901
I have a bissell proheat 9400 it is not dispensing the cleaner what can you do to fix it. Debra
Mar 25, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
420 people viewed this question
Top Bissell Vacuums Experts
Marvin
Marvin
Mike
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
