Question about Sharp EL-1750PIII Calculator
Date and time reset
No matter what size I zoom to, I can't make out the keys to press between the numbers and to complete the sequence. Can you help me?
Anonymous
    New Friend:
To set the time: First set to Rate to "SET" then say for example the time is now 1:33 p.m. enter 13 then hit the decimal then enter 33 hit the decimal then hit the time key and you are set.
Posted on Feb 11, 2010
Anonymous
    New Friend:
I managed to get the date, but I still don't know how to set the time. That's okay though because I don't need to time stamp my tapes. To be honest, I don't know what I did to finally get the time. First, I pushed the RESET button on the bottom of the calculator. Then, on the business side of the calculator, I set the GT . RATE SET button to RATE SET. Then I separated the month, day, and year by using the decimal point. But I don't know which key completed the sequence because I was trying so many keys. Since the date looked like 1.22-2010 while I was setting it, I never knew that I had actually accomplished it until I decided to give up. I cleared the calculator, hit the date/time key, and the date popped up looking like 1-22-2010. But it did not automatically print on the tape (like the one at the office does). So I hit the #/<> key and, voila!, it drew a dotted line from right to left and printed the date.
Posted on Jan 23, 2010
I'm forget admin password on hp 9250c. Please, how recovery admin password.
Cold reset for HP9250C
A cold reset resets the values of permanent storage variables to factory default. Often this is necessary
for clearing the HP MFP Digital Sending Server IP address.
The following items are cleared during a cold reset:
Embedded Jetdirect IP address
SMTP IP address
LDAP IP address
Embedded Web server password
All control-panel configurable items
The following items are NOT cleared during a cold reset:
Local address book e-mail addresses
Real-time clock (date and time)
Page counts and maintenance counts
Product serial number and formatter number
Service ID
Event log
To perform a cold reset
1. Turn off the digital sender.
2. Turn on the digital sender.
3. Immediately after turning on the device, press and hold down the #6 key (do not wait for the memory-count). When the three status LEDs are illuminated, release the #6 key.
4. Press the #3 key four times until the display shows COLD RESET.
5. Press the #6 key once to initiate the cold reset. The product will continue its boot-up sequence.
Oct 04, 2010 | HP 9250c Printer
How to reset panasonic 8020e
press the ''function' key the 'original size' key and the number '3' all in sequence. screen will display self test then press '9' or you can scroll down to 'unit maintainance ' press 'Start' key then you need to scroll to RAM initialize press 'start' key then scroll to 'All job clear' machine will restart when operation complete.
May 01, 2010 | Panasonic DP-8020E Black and White Copier
Old Casio CP-10 printing calculator w/calendar
just press the set button followed by the numbers for setting time
Jun 25, 2008 | Casio Office Equipment & Supplies
Canon MP11DX
press the date/time button
press and hold the = button
once blinking set the date
press the = button again
once blinking set the time
the "x" button changes A / P
press the + button again
Feb 29, 2008 | Canon LS-100TS Calculator
CANNON SURE SHOT 80U
1. With power off, press the MODE button to select the DATE mode.
2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
4. Use the zoom in (one tree) button to advance the number.
5. Repeat steps 3. and 4. to set each value.
6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
7. Press the MODE button and the power will switch off.
Jan 22, 2008 | Canon Sure Shot 80U 35mm Point and Shoot...
How do I change the date? I don't have a manual.
Jan 13, 2008 | Canon Sure Shot Z180u 35mm Point and Shoot...
Need to set the date and can't find manual--
Try this:
Dec 22, 2007 | Canon Sure Shot 115u II Date 35mm Film...
Cannot set the date on my Canon P23-DH V calcualtor
ok, have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved. do the same for time.
Nov 30, 2007 | Canon P23-DH Calculator
Date and time
Nov 07, 2007 | Canon Sure Shot 80U 35mm Point and Shoot...
How do you set the time on the Canon sure shot 80u
Sep 10, 2007 | Canon Sure Shot 80U 35mm Point and Shoot...
Sharp EL-1750PIII Calculator Logo
589 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
