Question about RTO Esab Plasma Electrode 0558001969 PKG/2
My plasma cutter just flashes fault everytime you try and use it. could it be the ground or would it be the electrod
Posted by travheaton on
Anonymous
    Champion:
  • 225 Answers
Check the main lead to the torch,if there is a cut or any hole in the rubber coating it will show fault,the unit uses high frequencey so if the lead has a cut it wont fire up.
Posted on Apr 11, 2010
I have a simadre cut50D an I don't have the ground cable can I still use it?
No. Check here for the specifics of how plasma cutters work: http://home.howstuffworks.com/plasma-cutter4.htm Without a ground cable, you cannot complete a circuit, and the physical basis of how a plasma cutter works doesn't function.
Sep 13, 2014 | Welding Tools
Uniplas 30 power light flashing
See if the torch electrodes MIGHT be stuck... welded together. They have to arc and then separate or unit will shut down.
Jun 15, 2012 | Welding Tools
Mishto ct 312 plasma cutter wont cut
not only earth problem, change electrode, nozzle and cathode
Mar 19, 2012 | Welding Tools
No pilot ignition, air is ok
Some times when I use my plazma cutter its a cut master 42 .I would some times have to turn it off and turn it back on for it to work .And here lately all it does is air come on and off its like its has a heart beat and then have to cut it off again . I have replaced the tips and electrodes .And nothing .I have took thee electrode out and clean the white dust build up and works fine for a little while
Feb 01, 2011 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
The lights are working for power and gas pressure but not the DC arc....BIG Repair problem?????? It a Pak Master 25 Plasma cutter from Thermal Dynamics bought 15 years ago
No, Try changing the tip. The one under thr node cone. If it burns back it will concave and increase the gap between the work and gun tungdten electrode.
Oct 30, 2009 | Welding Tools
Plasma cutter is burning through electrodes
Try turning down the juice. Tungsten is very durable, but is prone to melt also at excessive torch output.
Oct 26, 2009 | Welding Tools
Troubleshooting help
I would recommend replacing the electrode, and maybe the tip, other that that it sounds like you aren't getting a good enough ground for it to start.
Aug 23, 2009 | Hobart 500474 Airforce 400 Plasma Cutter
Plasma cutter
in order to cut the thicker steel just boost the air pressure this will allow you to thourghly blow through the steel. just remember not to turn it up too much. this should do the trick. please rate
Sep 15, 2008 | Miller 903777012 SPECTRUM 2050 PLASMA...
Plasma cutters problem
Depending upon the design of the torch (e.g., orifice diameter), electrode design, gas type and velocities, and the current levels, several variations of the plasma process are achievable, including: * Plasma Arc Welding (PAW) * Plasma Arc Cutting (PAC) * Plasma Arc Gouging * Plasma Arc Surfacing * Plasma Arc Spraying
Aug 27, 2008 | Miller 903777012 SPECTRUM 2050 PLASMA...
RTO Esab Plasma Electrode 0558001969 PKG/2 Logo
348 people viewed this question
Top RTO Welding Tools Experts
Bill Boyd
ray gallant
Are you a RTO Welding Tool Expert? Answer questions, earn points and help others
