Double check your brush istallation. positive side toward rotor bearing, if you put 12 vdc directly into brush pack and check with a meter at the 120 vac outlet and have low or no voltage, you may have no resistance in your rotor slip rings, excitor & main windings also need a resistance check. 12.6-16.7 ohms (rotor) 2.26-2.80 ohms (excitation) .26-.32/.28-.35 main or power windings. Note: unit running when appling 12 volts to brush pack. 2-5 second only, ( This test tells you the rotor & stotor are ok )
