Question about Kenwood KAC-9103D Car Audio Amplifier
KAC9103d been running great for a year, factory refurb. for a month been losing sub output. checked all connections again, everything good. Turned on went driving 15 minutes later lost bass ckd again red power lite on blue lite off. shut down and it turned on again had good bass and red and blue lite. Remote wire good ground good fuses good, amp is a little dusty any help is appreciated Thanks
Posted by bmecanic on
hoyzee1
    Novelist:
  • 150 Answers
Could be that you have a partially roasted(blown) coil on one of your subs which will function- but will keep tripping your amp.You can check that out just by using a different set of subs to listen to and by the process of elimination if the problem goes away then you know where the problem is at.Also check your gains you might be riding the gain a little high which causes distortion which causes heat(FAST) which will cause the amp to shut down completely or some amps will decrease output in a programmed attempt to save itself.turn the bass boost down to half if you even use it at all- that too can cause massive distortion in the amp itself,meaning only that if you have the bass boost on your deck turned up and then you turn the boost up on your amp the sound signal is then WAYYY distorted which will cause a thermal shutdown too. Last thing is to make sure that your subs arent running below 2 ohms because i believe that particular amp is designed to put out about 900 watts at 2 ohms.good luck
Posted on Jan 30, 2010
Wiring/sub-woofer not putting out!!
The remote wire from your head unit should be blue and there should be a wire that connects that to your amp. Make sure it is hooked up. Also, if you are using the high in put wiring up above, it shouldn't be mixed with your RCA. That wiring diagram is not needed for the subs. You should also check the gauge on you power wire that runs from the battery to the amp. If it is 4 or less it should be good if it is Copper Clad aluminum (CCA) it will put out power similar to 8 gauge copper wire. Most of the time the problem with the low output of subs is the amp wiring kit. You could have great subs and a great amp, but if the wire isn't any good it can sound like ****. Just FYI in case you weren't familiar with any of that. Always try to get pure copper wire when it comes to the power cable. You can google information about it. If you're wiring there is fine. Again, check the remote wires. Also check to see you have your amp levels turned up as well. As for the violet and violet/white. Those are referring to you speakers in your vehicle. Not your subs.
1helpful
2answers
I'm having a problem with sound from a Marantz SR48 MKII. I have a pair of Klipsch monitors connected to the "system 1" outputs on the Marantz and a Polk PSW100 connected to the "system...
I'd say you DO need to evaluate how the PSW is attached. I can't find the specific manual for it but the prescribed way for most subs that accept speaker level inputs (and HAVE speaker level output terminals) is run one pair of speaker outputs from the receiver to the sub and daisy-chain the Klipsh speakers from the sub.
1helpful
I've got a Cdx-gt300 series that will not output to the rear or front out jacks on the back. Everything else works fine and the setting is set to sub out, but when connected and the sub is turned up to...
check the sub works with known good signal from different source. if that works and all settings are double checked then you might try to reset the 300 series to factory reset. try to unplug from the 110 outlet then hold the on button down while plugging it back in this should re iniatalize the unit and if it still doesn't work you may have a hardware problem
I have a Kenwood 6140 installed in my Corvette Coupe. I have everything installed but the sound doesn't sound right. It lacks something and I'm thinking that the subs aren't on! Could this be my problem...
Normally if you have a factory ampped system and you remove the factory headunit you lose things like the factory sub. There are only 4 outputs on an aftermarket sub. In order to make your subs work you will need an aftermarket amp.
Onkyo M-282
check your amplifier output speaker impedance requirements..
example: 8 ohms...build a speaker 8 ohms in parallel or series connection..
check the impedance using ohmeter ..you must reach the required impedance..
use 1 cell battery to check if you speakers are in-phase...if one speaker did not ..reverse connection and check again ...to give the good sound...hope you understand my english..:)
4helpful
2answers
Basslink has no output, but Power LED and Servo LED always on.
One or more of the DC to DC outputs might be bad. Check the
/- 54v on the main PCB and the /-15v on the switching controller PCB.
Losing one side of the 15v will cause the limit comparator to rail and force the servo protection, even with no input signal.
Phoenix Gold Xenon 1200 mono not pushing subs and making noise.
This sounds like a problem with the head unit output to the sub amp. Are you using a Pioneer head unit? If so, you may have a problem with some surface mounted fuses inside the radio on the main board. Certain Pioneer head units have a common problem with these fuses blowing. They are fuses for the ground on the RCA outputs.
Let me know if this is the case, and if it is I can give you the part number of these fuses and tell you where they are located, but you would need good soldering skills to replace them. Also let me know what model number your head unit is.
Thanks,
Dave
CDA 9885 No idea why it suddenly stopped working
It sounds like you have a bad ground connection. You need to take the radio out and check all the connections. I bet you have a loose one somewhere. That is what the problem was with my bronco
1helpful
Subwoofer Output Not Working...
first check that the subwoofer function on the actual head unit is turned up,second check that the gain on the amp is at bout half way then check that it is on a lp (low pass setting)
then check that the boost on the amp is turned up.
please leave feedback.
cheers
Cant get the red led light green again
Disconnect all input and output cables and check. If the light stays red, it suggests an internal error. If not, proceed by first connecting the Sub wires and checking, then the input RCA's and checking. Remember to switch off the system before connecting/disconnecting, I suggest also removing fuses during this process.
Kenwood KAC-9103D Car Audio Amplifier Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
 Francisco Mauricio...
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
