Question about Bulova Chronograph Marine Star #96B99 watch
The date will not change, it will with the crown but when i advance the hands it will not change.
Arturs Kalnins
  • 2,338 Answers
Try to advance hands for full circle more (12 hrs more). If this does not work, then you will have to find your nearest watch repair shop, because one of the date change gear wheels is faulty.
Rate me, plz.
Posted on Jan 22, 2010
timjo28
    New Friend:
Im having same problem. just bought bulova and also after 24 hrs it is behind by 1 hr. really sucks
Posted on May 29, 2011
How do I change date on my Invicta 7352 ?
Usually, after unscrewing a *****-down crown, pulling the stem out one click will allow the date to be advanced by turning the crown in one direction or the other. Depending on the movement, a clockwise turn of the crown may advance the date and the counter clockwise turn might advance the day of the week, for example.
If all else fails, pull the stem out two clicks and advance the watch hands 24 hours for each day you wish to advance the date.
Jan 13, 2015 | Invicta Signature II Series Watch 7300
Tip
How To Set The Time/Calendar For Your Seiko Watch
<span style="font-weight: bold;">Time Setting for Models Without Calendar</span><br /><span style="font-style: italic;">Note: When setting the minute hand of a quartz watch, advance it a few minutes ahead of the time and then turn it back to the exact time.</span><br /> <ol> <li>Pull out the crown all the way. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Time/Calendar Setting for Models With Calendar</span><br /><span style="font-style: italic;">Note: The date will change gradually between 9:00 PM and 4:00 AM. For some models, however, it will change instantly when the hands pass the 12 o'clock marker at midnight.</span><br /> <ul style="font-weight: bold;"> <li>For models with date calendar</li></ul> <ol> <li>Pull out the crown to the first click.</li> <li>Turn the crown until the previous day's date appears in the calendar frame.</li> <li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol> <ul style="font-weight: bold;"> <li>For models with day and date calendar</li></ul> <ol> <li>Pull out the crown to the first click.</li> <li>Turn the crown until the previous day's date appears in the calendar frame.</li> <li>Turn the crown in the opposite direction until the desired language (bilingual) for the day before the desired day appears in the calendar frame. <span style="font-style: italic;">Note: For Cal. 7009 and 7019, push the crown back in to the normal position and then push it repeatedly to set the day.</span><br /></li> <li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date and day appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Note:</span> Do not change the calendar between 9:00 PM and 4:00 AM as it may not change properly. If it is necessary to set the calendar during that time period, first change the time to any time outside those hours, set the calendar and then reset the correct time. When the day shifts automatically to the next day, the other language will temporarily appear.<br /><br /><span style="font-weight: bold;">Note:</span> When setting the hour hand, check that AM/PM is correctly set. The watch is designed so that the calendar changes once in 24 hours.<br /><span style="font-style: italic;">Turn the hands past the 12 o'clock marker to determine whether the time is set for the AM or PM period. If the calendar changes, the time is set for the AM period. If it does not change, the time is set for the PM period.</span><br />
on Feb 15, 2011 | Watches
How do I set the day of the week dial on my Swiss Legend Chronograph?
If the day will not change when you pull the crown out to the first position (try both directions) then pull the crown out to the second position. Advance the hands until yesterday shows in the day window. Now set the date by putting the crown in the first position and set it to yesterdays date. Now advance the hands (position 2 until the date and day change and then set the time. Done
Oct 14, 2012 | Swiss Legend Commander Chronograph Blue...
SETTING DATE JUST ROLEX
After you unscrew the crown it is already in winding position. If you pull the crown, it will go to the date setting position. Further pull of crown will set it in time setting position. Try to pull the crown till you get it in correct date setting position and change the desired date. Do not use the date setting between 10pm - 2am, as this can damage date mechanism. The best way is to pull out crown to the time setting position and set the time to 6.30(anytime) and then push the crown in to date setting position and change the date to the previous day's date. Then again pull the crown out to the time setting position and advance hands forwards (clock wise) till hands pass 12.00 (midnight) and the date changes automatically to the desired one, then adjust the time, push the crown fully in and screw the crown on.
Jun 01, 2011 | Rolex Lady Datejust 179173SRJ Watch for...
How do i set the day (Mon-Sun) on my ax2013 watch?
When you pull the crown out there are two positions. The first is the day/date setting position. Turn the crown one way and the date changes, the other direction the day of the week changes. Set both the day and date to yesterday. It will become evident why when you finish. Now pull the crown all the way out and notice when you turn the crown the hands move. Advance the hands to the 12 o'clock position in a clockwise direction. As you pass 12 the date may begin to change. If not then you now know that was noon and not midnight because the date only changes at midnight. If the date did not change advance the hands all the way around 12 hours. This will now be midnight and the date should begin to change. It may be almost instantaneous or may take until 12:30 or so. Continue advancing the hands to 4 o'clock. You should see between midnight and 4 the day of the week advance. Now the day/date are correct for today and the final step is to set the correct time. Remember, you are now set a 4 AM. Advance the hands to the correct time. That means if it is 3 in the afternoon, you must advance past noon to 3. You cannot go backwards. That would be 3 AM!
Mar 24, 2011 | Giorgio Armani A|X Armani Exchange Black...
Setting the time and date
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Jul 09, 2009 | Rolex Explorer II 16570 Wrist Watch
Date change on my Tag Aquaracer Calibre S
Do as follows:1) At any time of the day pull the crown out and advance watch hands forward for EXACTLY 12 hours ( for example: if it's 6.35 on your watch, then after advancing hands it will be 6.35 again, just minute hand will be forwarded clockwise 12 full circles, while hour hand will be forwarded 1 full circle). Push the crown back in.
2) Pull the crown out to the date setting position and change to the desired date. Pull the crown back in.
Now your watch will be changing dates at midnight continuosly.
Rate me, please.
Apr 06, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Date function notworking properly
Do as follows:
Rate me, please.
Apr 04, 2009 | Tissot Le Locle T41.1.423.33 Watch for Men
How to adjust day date on older rolex perpetual day date watch
Mar 06, 2009 | Rolex Datejust SS
Bulova Chronograph Marine Star #96B99 watch Logo
151 people viewed this question
Top Bulova Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Anthony Ward
Anthony Ward
Are you a Bulova Watch Expert? Answer questions, earn points and help others
