Question about RCA 3-Device Universal Remote
Have a Magnavox TV , Rabbit ears
Have a Magnavox TV , Rabbit ears antenna,Digital stream converter box - DTX9950. Can turn the TV on and off and control the volume. RCA remote does not control the converter box. The converter box will change the TV channels but the RCA remote does not control the converter box. What should be done?
Posted by chrlshrl on
Tom Chichester
    Top Expert:
  • RCA Master
  • 57,289 Answers
You may have to try a different universal remote control.
Posted on Jan 20, 2018
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Need a smart antenna to go with the Digital TV converter box
First, you don't need a Smart Antenna, the manual is simply stating that your converter will use one if you have it. Any standard antenna will work, so there is no need for a coupon to pay for a new one, whether indoor or outdoor depending on your location and distance from each channel transmission tower. Since you don't give details of what antenna you are using, I will assume you have rabbit ears for each converter. Rabbit ears are notorious for poor reception and any metal or persons nearby will change the reception quality. I would recommend a roof mounted external antenna with splitters for the 3 converters if you have the option. If not, use an amplified internal antenna and mount it closest to the channel towers you will watch most and as high as possible. If you can find a smart antenna, which is an amplified indoor/outdoor antenna with a control cable for changing the direction of reception, for a decent price, you can use that but keep in mind that to use the control feature you will need one for each converter. Also, check antennaweb.org for information on digital channels in your area and their direction and distance. Antennaweb.org will also tell you if any digital channel in your area uses VHF frequencies. If they don't then a UHF only antenna will work fine.
Posted on Feb 18, 2009
ltfrc
Mike Schmidt
  • 227 Answers
SOURCE: codes for magnavox tv for rca converter box
005 007 045 049 050 054 055 064 097 098 099 153 154 160 170 174 177 181 210 230 234 252 258 259 272 274 283
Hope one of these works for you.
Posted on Feb 22, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: smart antenna
Just because you got lots more channels with the old analog broadcasts, it doesn't mean you can get that many with digital. With analog, you could get a watchable picture from a distant station even if it was weak. It just meant the picture might be a little snowy or fuzzy. It's a lot different with digital.
Digital reception is pretty much "all or nothing". That means either you get the channel or you get a "no signal" message. If the signal from the antenna is too weak, unlike the analog fuzzy picture there is nothing at all.
10 channels isn't a bad number, by the way. A lot of people are finding they get far fewer than that, even no channels at all. It all depends on your distance and direction from the station. If you go to www.antennaweb.org and click on "choose an antenna", they can help you determine what stations are on the air around your area, how far away they are, and what type of antenna would be required.
The "best" antenna is the one that gets the strongest signal from the most stations. For your specific location, this might be as simple as amplified rabbit-ears. Or it might mean a large rooftop antenna that you can turn to point right at the station. That option may not be available to an apartment dweller. You might just already have the best you'll get if you're getting 10 channels already.
Posted on May 17, 2009
Anonymous
  • 814 Answers
SOURCE: NEED MY RCA CONVERTER REMOTE TO CONTROL A MAGNAVOX DVD COMBO TV
Sorry it took so long to respond to your request for assistance. You can find the instructions and codes you need to program your television at the RCA customer support website [http://www.rcaaccessories.com/rcaaccessories/ ] Copy this web address and paste it into the address bar of your web browser. This will take you to the RCA main customer support page. Just go to the universal remote control section and find your model remote control. Use the model number to find the technical support information page. On this page will be a copy of the owners manual and the remote control codes to use with your products. I hope this information helps you with your problem of needing instructions and codes to use your remote with your products. Thank you for using FixYa and have a nice day!
Posted on Jun 22, 2009
stevenmiles1
Steven Miles
  • 34 Answers
SOURCE: Unable to pick up local channels using RCA DTA800
u may need a special signal enhancer that u can purchase online or at an electronics store....otherwise u may need to consider basic cable
Posted on Oct 11, 2009
Radio Schack converter doesn't program Ch: 25 like Magnavox!
Returned product to dealer. That fixed my proble.
Thanks...
Aug 19, 2009 | Philips Magnavox 20MT133S 20" TV
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Im not getting any signal weak or strong! What am I doing wrong?
What's your source for signal? You need an antenna to be the capture source for your signal that has a wire going from the antenna to the INPUT of the box. That's usually coaxial input. The box is the middle component between your TV and antenna.
Apr 26, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
NO channels now, we had some before!!!!!
Here is how you should have it connected.
1- Antenna (rabbit ears or whatever)
2- Converter box
3- Television
When you turn on the TV and the converter box, go to channel 3 on the TV. You should see the converter box signal there. If you do not see it try channel 4. Bring up the convert box menu and go through the AUTO SEARCH, not manual search. Now your box will search all the frequencies and add any stations that are in your area. Make sure you change channels with the converter box, not the tv. An antenna on the roof will still provide somewhat better range, but even rabbit ears will likely pick up something. If you still get no channels you could be too far away, digital signals have a shorter range than analog signals. You can check your local TV stations website or call to see if they are broadcasting digital yet.
Apr 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
NO SIGNAL on Magnavox TB100MW9 converter
Rabbit ears are not strong enough to pik up the digital signal. You need to buy a DIGITAL antenna. You can pick a powered one up at Wal-Mart, or any retailer for around 20 bucks. Once you have the proper type of antenna, go through the setup sequence again and then you will be in the "digital age". You will wonder why they didn't do this sooner!
Jan 13, 2009 | Insignia Digital-to-Analog Converter for...
Need to hook up dvd/vcr combo with converter box
Connect your rabbit ears to the Insignia. Connect the Insignia to the antenna input on the "cvd/vcr combo". Now turn on the television to show the "cvd/vcr combo".
The Insignia simply goes between your antenna and your television. In your case you also have a vcr so if you want the VCR to be able to play and record digital stations you will need the Insignia between the vcr and the antenna.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
Rabbit ears to digital conversion box
Your TV is old enough to have not only screw terminals for the antenna, but it sounds like it has separate UHF and VHF terminals as well. Pick up a 75-ohm to 300-ohm adapter (available at Radio Shack and probably most other places that sell TV's and antennas). This is a small cylinder-shaped part with a threaded antenna connector on one end, and a flat wire with two terminals on the other end. Connect the cable from the converter box to the round connector, hook the two terminals to the VHF antenna screws on your TV, put the TV on channel 3 and you'll be set.
You should also pick up a new antenna designed to work with digital broadcasting. If you use the old rabbit ears you were using before, you will probably not pick up all the channels available in your area.
Oct 31, 2008 | GE 35GT740 35" TV
Magnavox TB 100 MW9 STB Converter Boxes I'm trying to solve the antenna/rabbit ear connection from this converter box to the t.v. I only get a pic when the rabbit ears are connected to the back of the...
Analog signals have nothing to do with your problem. Make sure that the TV is set channel is set to 3 or 4 (cf read of Converter box for channel switch). The TV received signal from Converter box on Channel 3 (or AV Cables if you have them)
Jun 11, 2008 | Televison & Video
RCA 3-Device Universal Remote Logo
188 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
