Problem in highvoltage section
If the copy as you are saying are coming out good and clear, then you should check the machine setting. Maybe you pressed the dual page key by mistake or your paper setting on the tray does not correspond with the original document you are copying. Make sure you check this unless you are misreporting the problem.
Problem on high voltage unite or corona assemble
1.Clean & wash high voltage thoroughly.
2.Replace corona ware,and assemble new corona
upper and lawyer charger.
