HP OfficeJet 6210 All-In-One InkJet Printer Logo
Posted on Jan 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Paper jam error message..no jam
Although there is clearly no paper jam, as the printer will run a blank paper through it...it keeps giving me an error message stating "paper jam: Clear jam then press ok" but I can't clear this message and get my printer to print.
Clive
Level 3:
  • Master 4,362 Answers
  • Posted on Feb 15, 2010
Clive
Master
Level 3:
Answers
4362
Questions
0
Helped
1813560
Points
14613
Hello There this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
2answers
Why am I getting Paper Jam message?
check your paper size and setting. This will give you a paper jam every time.
Media jam fuser
replace the fuser unit. and replace the transfer roller and belt,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2answers
Paper jam error
One of the Common error for (Papper Jam) in printer is Error 0x000003eb.
Error code 0x000003eb indicated printer connectivity or printer installation error. If you are trying to install a printer driver but keep getting Error 0x000003eb prompted, make sure you have logged in as the administrator of the computer and then try installing the driver. If the problem still happens, try the below solution steps to solve this problem. The error message doesn't give you much information as it just says unable to install the printer and gives you the error code 0x000003eb.
The Error Message shows you: "Unable to install a printer. Operation could not be completed (error 0x000003eb)"
The printer connectivity or installation error 0x000003eb occurs because the drivers are somehow got corrupted or incompatible.
We know the printer is a very important part of our day to day life. We all need a printer to get hard copies of our important files and documents within a few minutes.
1helpful
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this...
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this several times but there is no paper to clear and the message keeps coming back. I've tried turning of the printer and unplugging it to clear the memory, but that doesn't help. Could it be that the chip on the ink cartridge is messing with the printer's operating system?
4answers
Error message keeps appearing "paper jam in tray 2" although there is definitely no paper jam.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it.
Printer erroneously reports a paper jam
Perform a hard reset of printer and see if that clears up the situation. Also uninstall and reinstall drivers.
k24674
Grand Canyon Tech
Grand Canyon Tech
