1994 Toyota 4Runner Logo
Posted on Jan 22, 2010
3vze v6 engine no power to fuel pump can only
3vze v6 engine no power to fuel pump can only find relay for efi this and fuse ok where to now?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1553
Points
Remove the passenger side of your dash "the glove box" there is a circuit opening relay tucked up behind the speaker it's small box. it reseavs signal from efi and maf then sends power to your pump. good luck...peace and love for all...
Which fuse under the hood of a 1989 Toyota Camry, controls the fuel pump
OK...for years the relay for the fuel pump on a Toyota is called the "Circuit Opening Relay" This relay is controlled by another relay...the EFI Relay. Both of these relays are fused. A 10amp Ignition fuse. A 10amp EFI fuse #3. A 10amp EFI #2 Fuse. Where are these fuses and relays? Start by checking under the Hood.
1996 Lexus 400 where fuel reset
To answer your question specifically it would be no. There
is no inertia switch that feeds the fuel pump that can be turned off or reset . The engine control computer turns on a series of two different relays to control power to the fuel pump. When in the start position the circuit opening relay and the fuel pump relay or both energize causing the fuel pump to run at full pressure or fast speed. From there the engine control computer determines which demand is on the fuel pump and either turns off the fuel pump relay and leaves
the circuit opening relay on to supply power through a resistor to slow the pump down for less demand. The EFI main relay is the main supply relay to both of these sub relays. The fuel pump is powered up ultimately by the 20 amp EFI number one fuse. All of these components are located in the fuse box under the hood. If the circuit opening relay is not working it's powered up by the 10 amp
ignition fuse inside the vehicle. It's unlikely it is the 10 amp ignition fuse because that powers up a lot of other things also.
Where is the fuel pump relay located
There are several "relay blocks" around the car. Info on what relays are in each one is printed inside the block cover, which is not a lot of help to start off with.
It appears to me that not all Camrys have that relay fitted, some instead only having a fuse. The 1MZ V6 has a big enough pump that it has a relay in block 5, under the hood on the left side looking forward.
There is not one on the 4-cyl just for the fuel pump. It is supplied by the EFI 15A fuse thru the EFI main relay and the circuit opening relay. See here p 177
http://www.turboninjas.com/camry/eg1.pdf
On the V6 it is similar, see p 575
http://www.turboninjas.com/camry/eg2.pdf
Audi A3 bmj engine v6
Sounds like your fuel pump has died based on what you said.
2helpful
2answers
What is the EFI fuse on a toyota camry
It supplies the EFI Main relay, which in turn powers the fuel pump, ignition switch, and starter relay. In addition it powers the ECM computer, so that if you wish to clear a trouble code from there, you pull the EFI fuse for 30 sec. See here p177
1994 Toyota Camry XLE V6 Fuel Pump Switch Location
The pump gets power from the circuit opening relay and the EFI main relay, which are supplied through the EFI fuse. p219 here
and
http://www.turboninjas.com/camry/be.pdf
Where is the in line fuse on fuel pump for 1994 toyota camry
My 1991 toyota 4runner keeps blowing the efi fuse and my engine floods gas. what could be the problem?
Check the EFI main relay, the circuit opening relay, and the fuel pump relay. Inside the fuel pump relay there is a switch controlled by a coil. During start, the fuel pump gets full power for a couple of seconds to build up pressure. Once pressure is good, the fuel pump relay is supposed to switch (via the coil) the fuel pump to reduced power. If the coil in the relay is bad, the reduced power setting is not available and the fuel pump will run at full power all the time. At this heavy current draw, it won't be long until the EFI fuse blows. This would also give more pressure than is necessary to the cold start fuel injector which runs on a timer. This extra pressure during the time that the cold start injector is operating may be the reason the engine is flooding with fuel.
2helpful
1993 Corrolla fuel pump does not make noise. put in new pump checked realays according to manual, still no noise at fuel pump I am at a loss. Any ideas
So you replaced the fuel pump because it didn't make noise? did you check for power at the Blue/Black wire? The Circuit Opening Relay powers the pump. Make sure to check ALL the fuses. Ignition and EFI fuses? does the Check Engine ligth come on with key on? it should, did you check the EFI MAIN relay
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
