I have Acu-Rite 00754 Wireless Weather Station and i"m trying to find out what the little white plug-in cable does? It attached to the of the remote, but isn't listed on any paper work.
Try taking the inside unit outside as close to the transmitting unit as possible for three minutes. The signal might lock on to the setting you want to receive.
The main thing with this unit is to put the batteries in the transmitter first, then in the base receiving unit. Then you can't really make any setting changes until the unit figures out the correct time through the radio signals it receives from Colorado, or wherever they come from.
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx found solution - search for - Q: My wireless weather station periodically beeps, why? A: .. unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. .. any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
There is no way to turn off beeping, d/s designers forgot. I had the same problem, another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. Don't use any sound features, ALL good now.
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx found solution - Q: My wireless weather station periodically beeps, why?
A: Make sure that any alert and/or alarm features are deactivated first.
Constant, sporadic beeping is generally due to the unit's ability to
transmits a signal. Wireless devices that may cause beeping but are not
limited to these devices are; scanners; computers w/wireless
keyboard/mouse; or other wireless weather instruments. Essentially, any
Another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. ALL good now.
I had the exact same problem, and found the answer on the Chaney Instrument FAQ page. There's no real
solution, but here is the explanation: Q: My wireless weather station periodically beeps, why? A: Make sure that any alert and/or alarm features are deactivated
first. Constant, sporadic beeping is generally due to the unit’s
when that unit transmits a signal. Wireless devices that may cause
beeping but are not limited to these devices are; scanners; computers
w/wireless keyboard/mouse; or other wireless weather instruments.
Essentially, any wireless devices transmitting on a radio frequency
