Question about Sony STR-DE845 Receiver
Sony str-de845 powers on, relay clicks sound works for a few minutes then relay clicks again and sound stops. display stays on.
    New Friend:
Hi there, can anyone help me? i cant seem to get my aiwa-d58 to get out of eco mode. no power, red light is on and every time i press the power button; the eco light clicks off and i no power supply to the whole unit. please help!
Posted on Jan 22, 2010
My sony str-de845 has an error
First I would try to reset it. With it off, hold the power button for about 5-10 seconds. It should either reset, or tell you to press enter to reset it.
Apr 26, 2013 | Sony STR-DE845 Receiver
Sony STR-DE845 5.1 Receiver, No Sound
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jul 11, 2010 | Sony STR-DE845 Receiver
STR-DE845 Stuck in Demo mode, tried the power and ...
To get the STR-DE845 ( or STR-DE945 ) out of DEMO MODE - Turn unit on and HOLD POWER BUTTON FOR A FEW SECONDS ...Turn unit off and when you turn it on again it should be reset ...It worked for me.
( Note : You may need to do this procedure before it goes into its actual demonstration of features ... Press and hold the power button immediately when it initially starts scrolling it's DEMONSTRATION MODE message . )
May 12, 2010 | Audio Players & Recorders
I have a Sony STR-DE845 receiver. The rear
Something is heating up to a point that it fails in the rear amplifier section. take it to a tech.
Jan 01, 2010 | Sony STR-DE845 Receiver
Can't get subwoofer working with sony model STR-DE845 receiver
read the manual
http://www.retrevo.com/support/Sony-STR-DE845-Receivers-manual/id/387ci973/t/2/
First, it must be a self-powered subwoofer, then you've got some settings to select in the receiver.
Sep 15, 2009 | Sony STR-DE845 Receiver
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
Turn on and the fusse explotion no have soun
Feb 15, 2009 | Sony STR-DE845 Receiver
Sony str-de635
It may need soldering of the display, could also be a bad resistor or transistor in the power supply.
Dec 08, 2008 | Sony STR-DE845 Receiver
Sound Problem with Sony STR-DE 845 receiver
Check for bad solder connections and tighten any and all screws that hold the circuit boards to the chassis.
Nov 20, 2008 | Sony STR-DE845 Receiver
Receiver making alot of clicking noises.
I Have a son STR DE 845 and the speakers make a popping sound when it is in DTS mode what is the problem.
Thanks,
Larry
Jan 20, 2008 | Sony STR-DE845 Receiver
Sony STR-DE845 Receiver Logo
776 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
