You might have the 2 coils stacked wrong. Seen it
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Flipped the holding and booster 180 on it post? They are keyed so front to back mounting. Would the gas even flow if these did not energize?
If the flame is coming on, does that mean I got the secodary coil right?
