Akai LCT2060 Television Logo
Posted on Jan 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It wont turn on...........
When i turn power on the power , indicator light does not come on....
please help me....
electronic & computer repair& servicre
Level 3:
  • Akai Master 12,061 Answers
  • Posted on Jan 22, 2010
Akai Master
Level 3:
Answers
12061
Questions
0
Helped
4006164
Points
36390
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Orange light on and it wont turn on
Is it an orange battery indicator? If it is, it means the AC adapter is charging the battery. Please charge the battery for 1 hour before you press the power button again.
Laptop froze now wont restart
remove the laptop battery and turn it on now check the led indications
1helpful
My archos 28 internet tablet wont turn on... the light comes on and then it goes off after like 7 seconds
LOL, you're up the creek. Never buy a computer that does not have a CD Drive on it because that is what you need now.
May the AC Adapter Power Cord is bad. Some of them have a indicator light on them when you plug them in the wall. Does yours have a light on it and does it light up?
When you plug the power cord in the tablet do you see any lights?
1helpful
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
5helpful
My vaio wont turn on and the green light in the back keeps blinki
The green light blinking in the back indicates that the power supply went bad and is not turning on, go ahead and get the power supply replaced. Normally that light is supposed to be fully lit and green.
23helpful
3answers
Power will not turn on
my orange light is on indicating that its getting power but it wont turn on. ive left it unpluged, left of, held power button, continuesly pressing power button but it wont turn on. help me please?
Wont turn on CANON PIXMA MP 160
Hi there
This is only a try it may work.
  • Turn off the canon printer
  • Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  • Hold the Power Button, release the Resume Button.
  • Not releasing the Power Button, double click “Resume” and release Both Buttons.
  • Click “Resume” for Four times
  • Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
  • Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
    All The Best: Pineworks
    1helpful
    4answers
    HP DV2036ea i have a blank screen on the computer
    Hello there
    Description.
    When pressing the notebook power button nothing is displayed on the screen or display. The cause of this problem may be a failed AC adapter, the memory modules (RAM) need to be reseated or a failed notebook system board component which will require an HP certified repair.
    Below steps will assist in identifying the cause of the problem and suggest the best solution. Test the AC adapter Follow the steps below to determine whether the problem is related to the AC adapter or your notebook system board.
    1. Remove the battery and disconnect all external devices from the computer.
    2. Hold the Power button for several seconds, with all power sources removed. This drains residual power from the system, and may correct many problems.
    3. Connect the AC adapter to a wall outlet and plug the other end into the computer.
    4. Press the Power button to start the notebook PC.
    If the notebook does not start or the display is blank then check the power indicator light or power socket LED. Check the power indicator light or power socket LED On newer models of notebook PCs, there is an LED or indicator light around the power socket on the notebook. Check to see if this light is on or off, when the notebook is plugged into AC power.The power indicator light or power socket light should turn on when the AC adapter is connected.
    • If the light does not turn on then the problem is most likely related to the AC adapter or the electrical source in your home or office. Go to the Light does not turn on section on this page.
    • If the light does turn on but the notebook does not start or the there is a blank screen then continue to the Light does turn on but the notebook does not start section on this page
    The light does not turn on when the AC adapter is connected If the power indicator LED is off, the AC power adapter may need to be replaced. To determine if the AC power adapter needs to be replaced follow the steps below:
    1. Ensure that the AC adapter is plugged directly into a known working wall outlet.
      NOTE: To check the wall outlet, plug in a different known working device like a light, radio etc.
    2. Check all of the following connections:
      • The connection from the power cord to the wall outlet.
      • The connection into the power adapter from the power cord.
      • The connection from the AC adapter to the notebook power socket.
    3. Press the power button again to test the notebook PC.
    If the power indicator light still does not turn on, then the AC Adapter needs to be replaced. Contact HP Service and Support for further assistance. Power socket LED or power indicator light is on but the notebook does not start If notebook power indicator light (LED) is on, the AC adapter is working correctly. The problem is a result of a hardware failure in the notebook itself. In some cases, reseating the memory module (RAM) may solve the problem.
    My high definition tv wont turn on. the power does not work.
    I would need the model number of your TV to help you, please respond to the same post with your model number and let me know if the power indicator lights up or not and wether it blinks or not.
    Top Akai Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
    matt martin
    matt martin
    Accurate TV Repair...
    Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
