If it is set to only play region 4 discs, then that's what the player can do - you cannot change the region code and I don't believe there is a hack to unlock this particular model to make it region-free.
The only types of discs acceptable are those which match the region of the player or discs which are 0 (region-free). I have never found a menu option to change region settings in any player. It is not modifiable nor accessible. There may be a player on the market which is multi-region compatible and will play your region 2 DVDs perfectly; just not this one. It is a restriction, not a fault.
Introduction The Px4x DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the DVD player.
Main Features The DVD Upgrade adds the following features to your DVD player: Multiregion capability Macrovision disable
Players Supported The following DVD players are supported by this version of the DVD Upgrade:
Modification Details Multiregion selection Nearly all DVD discs on the market today are encoded with a specific "region" in mind and are made in such a way that a disc designed for "region 1" will not play on a player designed for "region 2". This is so that the Hollywood studios can control the release of titles in different geographical regions all over the world. Our upgrade allows you to select between regions 1 to 6. Macrovision & CGMS disable All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD Upgrade disables Macrovision to solve any problems.
Operating Instructions You can select the region code by remote. This region will be tried first when playing a disk. Due to this design, the modification will work on the RCE (Regional Code Enhancement) protected DVD’s. In some cases it will be necessary to insert a conventional (non RCE protected) disc before playing a RCE protected disc. Follow the instructions as detailed bellow:
1. Turn the player on without a disc in it 2. On the remote control, press 'SETUP' 3. Use right arrow to select 'General' 4. Use down arrow to select 'Basic' 5. Press 'ENTER' on the remote control 6. Press 'Display' on the remote control You should see the region code and OSD version that the player is set to 7. Press 'Condition/Memory' 8. Press '1', '2', '3', '4', '5' or '6' to change the region code of the player The text will disappear 9. Press ' Display ' on the remote to control the region 10. Press 'SETUP' on the remote to exit. Play the disc This dident work for me but mayby work for you.
Check the owner's manual to see what region your dvd player is for. What ever that region is is the only region it will play.
Example: If you have a region 1 dvd player and a region 4 dvd, it will not play on that player. The regions must match. The dvd usually has the region it is for listed on the back of the dvd case near the bottom.
Also, Any dvd's that are Region 0 or are labelled "Region Free" will play on any player.
Probably can't, they are encoded for a reason. If you have a DVD drive on your computer MOST video players will play them.I use Nero and haven't had any trouble.
