Question about Toshiba 32AF41 32" TV
SOURCE: toshiba 32af41
Maybe a tube, sounds bad. Could be the CRT drive circuit though check the IC or IC's
Posted on Apr 23, 2007
SOURCE: blinking light wont turn on Toshiba TV CE19H15
Yes, it's quite possible that you indeed may have sufferd from a Power Spike, induced by lightning during the storm, esspecially if plugged in during said storm. I have had quite a few customers ova the years with this exact problem. I always advise my clients to unplug ALL devices during a storm, and for ones that simply cannot be unplugged then some sort of Spike/Surge Protection device MUST be used. As a matter of interest, I have written many a report to insurance companies to support a claim for a replacement.
Posted on Aug 08, 2007
SOURCE: Toshiba 32A32 won't turn on
just fixed one with that problem it was the vertical output ic Q301
that was shorted. try wicking it out. it is a LA7833S.
Postings say to be sure to use the Toshiba part
Posted on Aug 28, 2008
SOURCE: Toshiba TV will not turn on
Try to have the TV unplugged over night. If that does not solve it you may have to have the TV power supply circuit inspected for leaking capacitors, loose solders or may be a bad IC.
Posted on Aug 29, 2009
SOURCE: screen will not turn on, power light flashes red
try checking first your tact switch or your power button, then next look for open fuses or low ohm resistor on secondary part of your power supply then check your horizontal and vertical outputs for shortage and open circuits check also your horizontal drive stage.
Posted on Oct 14, 2009
May 20, 2012 | Toshiba 50A50 50" Rear Projection...
Jan 22, 2018 | Toshiba 32E200U 32 in. TV
Apr 23, 2011 | Toshiba 32AF41 32" TV
Nov 05, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Oct 30, 2009 | Toshiba 50HDX82 50" Rear Projection...
Feb 24, 2009 | LG LHT854 Theater System
Dec 16, 2008 | Toshiba 32AF41 32" TV
Apr 22, 2007 | Toshiba 32AF41 32" TV
Aug 19, 2006 | Sanyo DS27800 27" TV
Mar 27, 2006 | Toshiba 32AF41 32" TV
Feb 10, 2014 | Toshiba 32AF41 32" TV
Jan 24, 2011 | Toshiba 32AF41 32" TV
Oct 05, 2017 | Toshiba 32AF41 32" TV
90 people viewed this question
