Washing Machines Logo
Question about Kenmore Washing Machines
How to operate the washing machine model 110
Posted by naveedzesho on
Anonymous
  • 714 Answers
You can order a manual from Repairclinic.com
Posted on Jan 21, 2010
What are the specifications for a Kenmore 110.72570100?
The Kenmore Oasis High-Efficiency automatic washing machine, which begins with the model number 110, has 4.6 cubic feet of capacity that can wash up to 24 bath towels in one load. The washer has a width of 27.5 inches, a depth of 27 inches and an overall weight of 165 pounds.
Read more : http://www.ehow.com/info_8625471_specifications-model-110-washing-machine.html
Kenmore washer Model 110, Serial No. 27602690 won't spin
If wash cycle operates and water drains as should before spin indicates motor spinning. Chances are bad timer If your a real fixer you can remove timer control from panel check and clean all contacts internally making sure none are stuck closed . (Have had 3 110s in my time).not easy but can be done or buy new about 150$ reassemble and check operation.
Washing Machine not spinning water out of clothing
Here is an idea:
http://www.doityourself.com/forum/electric-large-kitchen-home-appliances/478342-kenmore-110-23832100-no-spin-issue.html#b
3helpful
2answers
1helpful
I have the kenmore heavey Duty 70 series 92273100 Model 110 that we just moved. Was working fine before. Now it won't stop filling, overflows, and doesn't go into wash cycle. It will only s
either the pressure switch is bad or the pressure switch hose from the wash tub to the pressure switch is kinked or plugged so air pressure cant reach switch and operate switch,remove hose at tub and blow into it and see if machine now operates,if not the switch is bad
Looking for a operating manual for a kenmore washer model number 110 4419590. I believe the machine was made in 1994. Thank you
Head over to the manufacturer's website.
www.searspartsdirect.com
Enter the FULL model number, and then can download a FREE manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sears / Kenmore top-loading washer does not dispense bleach
Remove the tray and check the proper operation of the solenoid for the door.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
2helpful
2answers
vince
Marvin
Marvin
