I have pentair intellitouch i5 - electric company shut power on our block for 3 hours, now the inside panel won't reset and outside panel tells me to go to check inside panel. How do I reset and get the system back online?
SOURCE: Pentair MasterTemp 400 Heater Will run fine for
This reminds me of some of the High temp sensors ive replaced. I would start with checking the pumps flow to the heater. Make sure there are no abstructions and at least 35 GPM (gallons per minute) running to the heater. If your flow is too low, you will trip the high limit sensor after a short while.
This could also mean you need to clean out the heat exchanger. When an exchanger gets dirty, it blocks the flow of water, slowing it down and "super heating" itdue to the water being in contact with the exchanger for too long. This will also trip the high limit and call for service.
If both the above items check out, contact me @ [email protected] and I will guide you further.
SOURCE: My Pentair easy touch control
I would call the Pentair technical support at 800-693-0971 number and they should be able help determine what to do next.
Pease let me know how this works out. Thank you.
