Question about Kenmore Washing Machines
Our Kenmore Model 110 - 82980120, Stock 29801, 118 G is giving a problem with the Automatic Process. It does not move by itself. It stays at the same place it is kept. If Kept at Wash it stays there, if kept at Rinse it stays there, if kept at Spin it stays there. It does not move from there.
  • 714 Answers
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Posted on Jan 22, 2010
6ya staff
SOURCE:
Freezer will not defrost itself. Where is the automatic defrost control located?
The defrost system is made up of the defrost heater, defrost thermostat and a timer. The defrost heater and thermostat are next to the evaporator which is behind a panel in the back of your freezer.
Suggest you go to sear parts direct and plug in the model number from the id tag (normally on the cabinet wall beside your crisper drawer) and it will give you an idea of the location.
Jul 14, 2011 | Kenmore 64802 Top Freezer Refrigerator
Kenmore 70 series model #97573200/stock # 75732. It's a gas dryer with an electric igniter. The problem is, dryer runs but there is no heat. I'm thinking there's a problem with the igniter? ...
if the ignitor is lighting up, the problem is going to be in the coils that are attached to the gas valve itself, heres what they look like http://www.applianceaid.com/images/2coilsgenaralgas.JPG
Jul 04, 2011 | Kenmore Dryers
Dryer won't stay running after pushing the button.
that isn't the model number,it will start with 110. or 417.send the full model number and i can look up your dryer,most likely it's the even heat board or the motor relay but without the model number i can't look it up for you,these parts are in the top console,call the parts store give them the model number and they'll give you the right part or send it to me,let me know what you find
Jul 20, 2010 | Kenmore 63942 Dryer
My Kenmore dryer "Start" button does not stay depressed.
a complete model # from inside the door would be helpful, on wost dryers when this occures the motor is packed with lint so the sentrifisle switch cant move from the pastion to the run or the switch on the motor itself is bad, the run windings in the motor could be bad. some of thethe more complicated dryers have a relay on their control board than burns out. try blowing out the motor with compressed air or the blow end of a shop vac use the skinney attat. to concentrate air
Dec 08, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
I have a kenmore canister model number 116.2645083 I need a replacement motor. I was given 2 different numbers: 1. 4147248 2. AC92FAUX200 I can find the 2nd motor, but it doesnt have the 4 wires like the...
Greetings from GoVcauum.com,
Ok, so good news, I have looked up your model number for your Kenmore vacuum and found that your Kenhmore canister takes the motor AC92FAUX2000.
#13 on diagram Image not available Motor Number: 4147248 Substitution: 705357
#13 on diagram Image not available Motor Number: 4147248 Substitution: 705357In stock
You may buy this part from the link to GoVacuum.com above. I have personally gone back and checked this motor, and it does have 4 wires that come off the motor itself.
I also verified this by pulling up your parts diagram for your model, and it did call this part number as well.
We offer the best return policy in the industry. We give you 60 days to return any product purchased from GoVacuum. We will even include a return label with every order, and if for any reason the motor doesn't fit, send it back with the free return label, and we give you a full 100 Refund, no restocking fees.
Please feel free to call me or email me if you have any further questions.
Chris Jones
GoVacuum.com
1-866-468-2288
Nov 27, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Refrigerator stopped.
There is no fuse in this refrigerator other than a fusable link located in the ice maker harness at the ice maker itself. There is an automatic reset breaker overload assm located on the side of the compressor that controls only the voltage to the compressor itself. Give specific details about your problem. Do lights come on, fan or fans run? supertechks
PS:find the model # on the identification plate, it will start 106.########
Nov 21, 2007 | Kenmore 64802 Top Freezer Refrigerator
Washing Machines Logo
380 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
