Dreamweaver cs 4 for windows gives flash plugin error while we look in live veiw i tried with uninstalling dreamweaver,deleting preference files, reinstalling latest flash player Pls Help Imtiyaz
right click taskbar, click task manager...under process tab look for Updater.exe, click it to highlight it, then at the bottom is a button to 'end task' click it. the program should terminate. if it pops back up then it could be a virus or malware. if that is the case...run malwarebytes anti malware scanner...its free and works very well. or you can search for it and manually delete the offending file....also run ccleaner..its another free software...could be that you just need to have the registry cleaned of old registry settings of programs uninstalled long ago.. let us know how you go on that.
When you embed sound in a webpage, the person viewing that sound has to have the right program to play it. Some audio files require a player plugin in order for this to work. If you are just trying to include a normal website sound file such as a wav file, the browser will know what to do. Also works for avi files. You can't put a song from a cd onto a webpage. You have to upload the song to your server, then you simply use the href or embed tag in your html code to make it play.
You may try running a repair of the program from the Control Panel > Applications list. (If you are running Windows.) Basically follow the same steps you would to Uninstall the program. Bring up the Control Panel. Find Programs. Select Uninstall a Program. Click on Dreamweaver. When it is highlight, look toward the top of the window for a "Change" or "Repair" option. If there isn't one. Click "Uninstall" but BE VERY CAREFUL. Once the Uninstall box pops up there may be a radio button (like an option to click) for "Repair" - That should restore any lost files and hopefully resolve the issue. Otherwise, a complete uninstall and reinstall may be warranted. Hope this helps! - Cheers! (See image for example)
Navigate to C:\Documents and Settings\USER\Application Data\Macromedia\dreamweaver mx 2004
Rename the Configuration Folder to “Configuration old”.
Note: "USER" is your Windows username. If you are unable to see
the “Local Settings” folder, it may be possible that you don’t have
explorer set to view hidden files and folders. In explorer, click on
Organize > Folder and Search Options, click on the View tab and
enable “Show Hidden Files and Folders”. Click ok.
yes, dreamweaver 3 is quite updated but it may work better then the new one with some old computer. The newest dreamweaver release is dreamweaver CS. Here is macromedia page for it: http://www.adobe.com/products/dreamweaver/?promoid=BPDEC
Do not confuse dreamweaver 3 with adobe creation suite 3. Adobe Creative suite 3 is the latest suite containing dreamweaver cs and all the latest software distributed Macromedia.
I made a tutorial that shows how to fix it here: http://www.funkytower.com/2008/09/22/dreamweaver-mx-and-vista-fix-insert-tables-best-fix/
I've written a few on this before, but this seems to be the best fix. You more than likely won't get an answer because there are still alot of people using XP and they don't have this issue.
The fix is basically this: going to the program root folder and finding and modifying the function for inserting a table (which is either or both c:\program files\macromedia\dreamweaver mx\configuration\objects\common and/or c:\users\your user name\appdata\macromedia\dreamweaver mx\configuration\objects\common) This file happens to be a simple html file, so it's easy to tweak.
The tutorial's URL I gave above will give you all the details.
Macromedia Dreamweaver for the first time, or on a new site for the first time, you need to define the Web site so that Dreamweaver can work with it. This process includes naming the site, placing the local files on a directory on your hard drive, and showing Dreamweaver where those files will be published on the Web. Follow these easy instructions to define a new Web site for Dreamweaver .
First, you should go to the "Site" menu and choose "Manage Sites".
As you can see from the image below, this will open a dialog window. Choose "New Site" from the "New" button.
Open Dreamweaver and Start the Site Definition Wizard Name Your Site
Using Server Technologies on Your Dreamweaver Site Where Should You Edit Your Dreamweaver Site Files Defining Access to Your Dreamweaver Site Always Test Your Connection Site Check-out and Check-in with Dreamweaver Review Your Site Definition Your Site Now Appears in the Manage Sites Window Start Editing Your Files in Dreamweaver
