Question about Invicta 3209 Lupah Diver Watch
Self winding is this watch self winding
Posted by jphonebook on
Arturs Kalnins
  • 2,338 Answers
Your watch is battery powered. It is NOT self winding.
Posted on Jan 21, 2010
I have a folio 21 jewels limited addition watch. I dont know how to wiend it. And I need to know what its worth.
I have no idea of the value.
You say that it's self-winding, but that you don't know how to wind it? Just wear it - the movement of the arm and wrist winds the watch. If the watch is fully wound down then it may take a while for the watch to have enough power to restart. Some automatics will allow you to wind the watch in the normal way with the crown.
Oct 21, 2017 | Black Watches
I cant get the arms to automatically set themselves
About Self-Winding Automatic Watches - Self-Defense Armory
www.selfdefensearmory.com/aboutautomatics.html
about mechanical watches, self-winding, automatic watches. ... Secondly, and this is where it gets a little hazier, people buy automatics for reasons that cannot be clearly ... Self-winding automatic watches depend on the movement of the arm to ... Avoidsetting the day and/or date (if your watch has these functions) at night.
About watch movements: technical details
Dec 26, 2015 | Casio GA-110-1B GA110 G-Shock Alarm World...
Self-winding Seiko watch stops ticking.
Take it in to a watch repairer. Sounds like the self-winding spring is worn if not so then the watch repaier will find the problem. There is nothing you can do so do not attempt to fix it.
Apr 28, 2012 | Watches
Stops after i take it off, I have to shake it to get it going again, problem is intermittent, I have no clue...
Your watch is self winding and will run down (if fully wound) for about 2 days.
This type of watch thrives on use and if not used will stop. To avoid having to re-wind by shaking, it should be worn every day.
(Some makers say that to full wind up their self winding watches, they need to be shaken (gently) aboiut 200 times).
Apr 15, 2011 | Rolex Daytona 116520 Wrist Watch
My watch is not working,,is there a battery i must change?
Your watch is a self winding type and does not contain a battery.
To wind it up, swing it from side to side gently for a few minutes (this operates the self winding mechanism).
Self winding watches thrive on use and will only run for 2-3 days if not worn.
Mar 05, 2011 | Rolex Daytona 116520 Wrist Watch
I bought it new and then a few weeks later the battery seemed to stop. I did not wear it often. I heard some watches do not use battery and function with the movement of one's arm. Is this the case for...
If the watch is a self winding type, then it generally says "automatic" on the face. These will run for about 2-3 days if they are not worn, as the self winding action only works when the user is moving).
Battery driven watches should run for at least a year before needing a replacement, so if it has stopped already, it could be self winding or manually wound type. Some self winding watches can be manually wound so you could try this to see if it starts.
Aug 14, 2010 | Watches
Self winding Prague men's watch. Will not keep wind
GOTO
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 04, 2010 | Prague Sunray 49025G
Have old Mickey Mouse self winding watch. Bought
I will explain from the last question asked. To get it going you have to visit your nearest watch repair shop and ask for estimate. Shop owner told you things he/she do not understand at all - self winding watches CAN NOT BE OVERWOUND, so, there is the question: are you sure this watch is self winding? I've experience of 26 years of watchmaking and have never came across Mickey Mouse watches having self winding movements. As far as I know, all MM watches are battery driven, but in case if you really have the mechanical one - you are lucky. That means there were past times when those watches were fitted with mechanical movements and now they are rarities. Even if your watch is not self winding, but is mechanical (not battery driven), visit your nearest watch repair shop and ask to check this watch out. In case if it is mechanical - pay the money and get it fixed (you will be a winner anyway). If it is battery driven - put it on your shelf where your's mother in law picture is and treat it accordingly. Rate me , plz.
Feb 18, 2010 | Disney Watches
The watch is self widing. ait just stopped working
Yes I do. Don't try to fix your watch.
My watch maker friends have told me that generally speaking, the reason most self wind mechanical watches stop is: (1) they need cleaning or (2) the screw that holds counter weight in the watch (that actually does the winding) comes unscrewed. He said most of the watches that have been worked on by the customer have lost the screw.
My advice remains have your watch looked at professionally.
Any other concerns my friend?
Jan 14, 2010 | Watches
Kenneth cole k3771, is the self-wind function working?
Self winding watched should not need to be wound as long as they are being worn.
To tell if the self winding mechanism is working, hold the watch close to your ear (hold it vertical, as though it was on your wrist) and rock it gently. You should be able to hear a ratchet operating (a soft clicking noise).
I can't help thinking your suspicion about the mechanism having failed, sound very likely.
Jan 05, 2010 | Kenneth Cole Chronograph Watch for Men
Invicta 3209 Lupah Diver Watch Logo
194 people viewed this question
Top Invicta Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Kardoc
Are you an Invicta Watch Expert? Answer questions, earn points and help others
