virgin media codes 00 CF 53 OC 33 79 61 71 85. 01 52 5E 8D 45 FC 75 F6 4A. The dollar signs are actually S for the scrambled channels, check yours with these, it only takes one wrong number or letter for them not to work.make sure the emu is showing on when on nagrivision,and make sure you store codes in after each line good luck.
Star View 3 The Box Super when channels discappear ;o)
1. Press menu then Factory Setting & Enter code 0000 to reset.
2. Exit to main menu & enter 1570 to get into the CASS SYSTEM & turn EMU on
3. Reinstall channels (Goto Installation, Cable network (try TW first & if no channels try NTL then C & W and so on - I'm with Virgin & used the setings for TW) & Voila ;o)
Nb: You may have to redownload channels so reconnect yr box to the computer & follow the link below
http://www.4shared.com/file/76886028/fd4ac296/GTRom_the_box_Super_8102e_081129.html?err=no-sess
& press download !!!
I assume it plays back a pre-recorded film with no problem? Check your antenna is connected to the input of the VCR or your cable box. If you have a cable box connected via a scart connector, then select AV channel on the VCR & select the programme from the cable box. If you are using the antenna the go into the set up menu & retune the VCR into your incoming channels & ensure the flylead from the output of the VCR (at the rear of the video next to where the antenna cable is positioned) is connected to the input antenna socket of the TV.
Subject: Star View 3 The Box Super when channels discappear ;o)
Assumin the Eurovox is similar to the Starview box, this might work :-
first upate it from your pc with firmware
v3.00 second press menu then type 1570 or what ever your number is to
get into nagravision then go to SET DEFAULT KEY PRESS OK TURN ON KEY
EMU .now exit back to tv it should say channel updating when it gets to
%100
