Question about Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304)
I am trying to locate my wep key - Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304)
Posted by Avanti0205 on
Fixya Guru
  • 687 Answers
Goto Nirsoft WirelessKeyView you can recover your own key stored in the WZC Service if it is running that is.
Posted on Jan 21, 2010
Anonymous
    Guru:
  • 480 Answers
Anonymous
    New Friend:
  • 3 Answers
Look underneath the router for the WEP key or call your service provider or manufacturer to reset it for you
WHERE DO I FIND MY WEP KEY? I AM TRYING TO CONNECT MY PS3 TO THE INTERNET
WEP key is also known as your Wireless password. It is located in your Router Configuration settings. Access the default gateway of your Belkin Router and go to Wireless Settings. Look for WEP and it will provide you the WEP password to connect your PS3.
Jun 20, 2011 | Belkin Computers & Internet
Were is a wep key located on a nintendo ds i
the WEP key is actually located on the wireless device it is trying to access.
Jun 13, 2011 | Computers & Internet
We are trying to find internet connection.What are all the wep keys meanings?
wep key means a security key to trouble shoot this follow this guide. This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
May 29, 2010 | Nintendo Wii Console
I need a wep code for an Actiontec GT704-WG. Trying to setup internet connection for wii and the code that is on on the modem does not work .
here is a setup guide to help you get the wep key. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
May 15, 2010 | Actiontec GT704WG Wireless Router...
Ok. so im trying to get my WEP key for my PS3 so i can have the inthernet....but i have no idea where or how i can find my WEP key. Please help
The WEP key is going to be located in one of the menus of the wireless router your using. Look at the manual for your router and you will find out the address to type in your browser to get to your wireless router menu. Then from there you can find the WEP key.
Apr 28, 2010 | Video Game Consoles & Games
Error code 52030 ,when trying to hook up to wireless internet
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Mar 11, 2010 | Nintendo Wii Console
Error code 51330 trying to conect to the internet get so far then get this
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Feb 09, 2010 | Nintendo Video Game Consoles & Games
Error code 51330 on the wii.it will not except my
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
Need further troubleshooting? Go straight to Nintendo's website at:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Nov 19, 2009 | Nintendo Wii Console
Cannot connect to internet error code 51330 is showing
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Need more info? Check Nintendo's website at:
How do i reset my wep key or locate my old one
To locate your wep key.log into the router under wireless security there you should see it.If not you can use a paper clip to reset it.The hole is at the back next to the ports.
Good luck
Sep 28, 2009 | NetGear WGT624 Wireless Router
Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304) Logo
141 people viewed this question
Top Belkin Computers & Internet Experts
Mike
Michael Thomas
Michael Thomas
Lee Hodgson
Lee Hodgson
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
