Logitech ClickSmart 310 Digital Camera Logo
Question about Logitech ClickSmart 310 Digital Camera
I can not install under windows 7
Posted by patricioc on
  • Logitech Master
  • 6,611 Answers
Unfortunately, Logitech has chosen not to support this camera under Windows Vista or Windows 7. Thus there are no current drivers for Win7. There is a way to install your camera if you have Windows 7 Pro or Ultimate: install the XP mode (a virtual computer). Install the camera to the virtual computer. You may need to save the files to an external media to share them between the two "machines".
I hope this helps.
Posted on Jan 21, 2010
Can no longer check my ink level.
Sometimes Windows 7 drivers need to be downloaded from the HP support site. Also, make sure you have installed the application on the CD that came with the printer in addition to the printer drivers. That is what you would have run under Programs before. If your Windows 7 computer was not used to manage the printer before, you will need to install the HP management tool on it in order to see ink levels.
tip
Installing Windows 7 to ANY Netbook Using USB Drive
To copy the Windows 7 ISO file to a USB flash drive Before you begin:
  • Make sure you've already purchased and downloaded the Windows 7 ISO file to your PC.
  • Make sure you've copied any files on the USB flash drive to an external location. The Windows 7 USB/DVD Download Tool will erase any data on the USB flash drive.
  1. Click the Start button d49affd.jpg, click All Programs, click the Windows 7 USB/DVD Download Tool folder, and then click Windows 7 USB/DVD Download Tool.
  2. Under Step 1 of 4: Choose ISO file, click Browse, browse to the Windows 7 ISO file you downloaded, click it, click Open, and then click Next.
  3. Under Step 2 of 4: Choose media type, click USB device.
  4. Under Step 3 of 4: Insert USB device, click your USB flash drive in the drop-down list, and then click Begin copying.
  5. If you see a dialog box that says that there isn't enough free space on the USB flash drive, click Erase USB Device, and then click Yes.
  6. When the process is finished, click the Close button 890548ff-eff6-4f93-ba12-92692a835f86.jpg in the upper-right corner of the window.
To install Windows 7 using a USB flash drive If you don't need to start your netbook using the USB flash drive, you can simply browse to the USB flash drive, and then double-click setup.exe to begin Windows 7 installation.
To start your netbook using the USB flash drive:
  1. Turn off your netbook, insert the USB flash drive, and then restart your netbook.
  2. Press any key when prompted, and then follow the instructions that appear.
  3. On the Install Windows page, choose your language and other preferences, and then click Next.
    If the Install Windows page doesn't appear, and you're not asked to press any key, you might need to change some system settings. To learn how to do this, see Start your computer from a Windows 7 installation disc or USB flash drive.
  4. Follow the instructions to finish installing Windows 7.
on Apr 19, 2010 • Computers & Internet
Micrografx creatacard 3 gold - repeat only micrografx, not american greetings
Micrografx Creatacard Gold 3 was created back in the Windows 98 days and most likely the installer is a 16-bit installer. Windows XP worked OK with 16-bit installers, but Vista, Windows 7 and Windows 8, 8.1 will not work. There is a work-around I found ( I actually found this fix for installing Photoshop 7 under Windows 7) and it works! I was able to install Photoshop 7.0.1 under Windows 7 Pro x64 edition and it works great!
Perform a search for Install-Photoshop-6-or-7-on-Windows-7 or go to this website http://www.wikihow.com/Install-Photoshop-6-or-7-on-Windows-7. Under this website, Look at Method 3 of 3 .
Stuff you will need:
1. A working Windows XP -SP3 system where you can install the Free Scalable Smart Package. You may be asking why? You will need to install the Micrografx Creatacard Gold 3 on this system with the "Discovery Program" running so it can create a new 32-bit installer
2. A CD-RW or a Memory Stick where you can copy the new .MSI file created and run it from Windows 7 x86 or x64 bit system.
3. Download the Free Scalable SmartPackager program. This used to be called WinInstall LE but they have since changed the name. You can find the program here http://www.scalable.com/smart-packager-ce-msi-package/. This is Free, but you still need to register to get the software. The latest version as of last week is v2.0.2.
4. Printed out instructions from the website so you can follow along. Once you perform this, you may end up trying this for other "older" software as well.
Basic Overview:
1. Under your Windows XP - SP3 system, install the Packaging software called Scalable SmartPackager v2.0.2
2. Once you have installed the SmartPackage program, it is a good idea to Reboot your system so all files get updated properly.
3. Start the icon called Smart Packager.
4. Under Smart Package, make sure you are under the Welcome screen and click on the Discover a new Package under Common Tasks.
5. When the Blue Discovery screen pops up, click on the Next button
6. Under the New Package Information screen, type out Creatacard Gold3 or something that you like
7. Under the Output Folder, Click the Browse button and select a folder or location where you want the new Creatacard Gold3.msi to be saved. Make sure you click on the Show advanced Options box below and Then Click Next
8. On this screen, you will now need to Click on the Start Discovery. This is what the SmartInstaller program will use to see where all the files are being installed to, etc when you run the Creatacard Gold 3 installer.
9. Insert the Micrografx Creatacard Gold 3 CD in the drive and install the program like you normally would. Please remember to install any of the Extra Free fonts as well during this time since this will be the only time you will have to create a new 32-bit installer (unless you run this process again)
10. After the Creatacard Gold 3 program has installed, verify it is working by Running the program and testing out various things within the program. (This is while the Discovery is still running in the background)
11. Once you have verified the Creatacard Gold 3 program is running properly (under the Windows XP system) then go back to the Discovery window and click on the Red Stop Discovery button and then click on the Next Button.
12. Make sure the Add new package to Smart Packager is checked and then click on the Finish button. This will now save the new "updated installer" MSI file over to the folder location you specified under option 7 above.
13. Copy this new *.MSI file you just created and either burn it to a CD-RW or copy to a Flash drive and take this file over to your Windows 7 system.
Please note, these instructions are an overview and may not contain the entire correct order. The last time I performed this was back in January 2014 when I first discovered the article about using Scalable Smart Packager to re-create an installer file into a true 32-bit installer.
For me so far, the installer has worked with Photoshop 7 and several Photshop plugins like KPT5, KPT7, etc.
I make no guarantees that this will work in your situation but it could not Hurt.
Plus, should you have problems removing this program I would recommend you try this Free program called Revo Uninstaller v1.95. This is Free for Home/Personal use only.
Hopefully you can use the above instructions I provided and get this great program to work under Windows 7.
Please let us know if this process worked for you or not.
Hi , i cant install canon pc1230d in windows 7 computer. Thanks
There is no driver for your unit under Windows 7
Workaround :
If you are under Win 7 Ultimate or Pro or Enterprise , you can download and install a free virtual version of Win XP from : http://www.microsoft.com/windows/virtual-pc/download.aspx
This is the ultimate solution to ANY compatibility problem. You just use XP mode to do operate your device then go back to Win 7 in one clic where your modern processing software is.
Under other versions of Windows 7 , you need to have the XP install disc to install a virtual version with a third party software such as WmWare Player from
http://download.cnet.com/VMware-Player/3000-2094_4-10470784.html
2answers
I am running Windows XP as a virtual PC under windows 7. I find that Mathcad 11 will not install. It will install directly under windows 7 but will not run. Mathcad 11 did run just fine under XP but...
The software don,t support Win 7.See this chart form portal:
Platform Support Platform Version Supported CPU ODBC Driver Support
Windows XP Professional x64 Edition
Base OS
Intel Pentium/Xeon family with EM64T
AMD64 family
32-bit
Windows XP Professional Edition
Service Release 2
Intel Celeron family
AMD Opteron family
Windows XP Home Edition
Windows 2000
Service Pack 4
After instaling windows 7 my laptop did not pick up my ati radeon xpress 1250 ? what can i do to fix this
AMD’s DirectX 9 ATI Radeon graphics accelerators are not officially supported under Windows 7. If the user chooses to, they can install the ATI Catalyst Windows Vista graphics driver under Windows 7. Please be aware that none of the new Windows 7 graphics driver (WDDM 1.1) features are supported (as the Windows Vista level graphics driver is limited to WDDM 1.0 level support). Using the ATI Catalyst Windows Vista driver under Windows 7 is not officially supported by AMD, and as such AMD will not provide any form of customer support for users running in this configuration
CANT GET SKYPE TO INSTALL IN WINDOWS 7
Skype probably don't have there program setup yet to run under windwos 7. Windows 7 is just new enough, a bit and to see if they skype develops a install software for windows 7
Nov 14, 2009 • Skype IM
7helpful
5answers
Why my acer e500 cannot install 64 bit window 7 it say no driver when need to choose hard disk to install
you need to install Uli sata drivers in order for your motherboard to recognize the harddrive and cd drive.
download the drivers here: http://www.soft32.com/download_184082.html
and put them on a cd or memory card, when the system prompts you that you have no harddrive, you can load the drivers from a memory card or cd however if you use a cd you will face other issues. then you will be able to install windows 7 ;)
I did it on my acer e500 and it runs good.
I didn't install the 64 bits version though but the 32 bits.
for all the people saying that his pc is too old: if the pc can run under vista, it runs better under windows 7
30helpful
4answers
9helpful
ATI Radeon X1250 for Windows 7
Note: AMD’s DirectX 9 ATI Radeon graphics accelerators are not officially supported under Windows 7. If the user chooses to, they can install the ATI Catalyst Windows Vista graphics driver under Windows 7. Please be aware that none of the new Windows 7 graphics driver (WDDM 1.1) features are supported (as the Windows Vista level graphics driver is limited to WDDM 1.0 level support). Using the ATI Catalyst Windows Vista driver under Windows 7 is not officially supported by AMD, and as such AMD will not provide any form of customer support for users running in this configuration.
Top Logitech Cameras Experts
Steve
Marvin
Marvin
Are you a Logitech Camera Expert? Answer questions, earn points and help others
