ScanWise for Agfa scanner does not run with OS X 10.6.2
When the window opens, ScanWise cannot find ColorSync systemprofile.
Calibrating the monitor as suggested, does not help.
Any good idea?
I would appreciate help
Wolfgang Tscheu
In the mean time i bought another (all-in-one) printer, which has the ability to scan also. So the Agfa scanner was given away........In the mean time i bought another (all-in-one) printer, which has the ability to scan also. So the Agfa scanner was given away........
You can't post conmments that contain an email address.
hi,
please check whether you have installed the software in Administrator mode only because it can restrict you in establishing the connection..Also try to restart before you reinstall your Scanwise..hope this helps you..thank you!!..
Although Agfa no longer supports their scanners with drivers and software updates, some Vista and Windows 7 users say they are still able to install the XP software and get it to run. In another thread, broccauley said: 'I got my Agfa Snapscan 1212U scanner to work fine with Windows 7. All I did was to install the XP Agfa Scanwise 2.0.0.9 software FIRST (available from Agfa website). Then I went to Devices and Printers, right-clicked on the 1212U and chose "Troubleshoot" - Windows then found and installed the driver automatically.' Good luck!
Uninstall the scan software and install the snow leopard software not using the upgrade path. If the problem persist, install only the orignal scanner software.
I had the same problem. Upgraded from G5 PowerPC Tiger OS to iMac Snow Leopard. Have a Snapscan 1236U (ScanWise) and got the same error message ("cannot find the current ColorSync System Profile"). Downloaded trial version of VueScan (www.hamrick.com) , scanner worked, so purchased the VueScan Professional Edition ($79.99) (Standard Version is $39.99). My scanner is now working GREAT!
There is a textfile named scanwise in the directory of scanwise (version 2.0). There could you find some more information about your communication problem. Sometimes the info is a little bit short, but maybe this info can help you to get additional support.
I have installed Snow Leopard on my Mac and my Snapscan Touch AGFA will not work. This is the message I get on opening -
ScanWise can not find the current ColorSync System Profile. Please recalibrate your monitor or select another system profile with ColorSync Control Panel
Can anyone tell me how to fix it.
