Possible paper jamb or open cover.
If you recently "pulled" paper out somewhere, there may be a tiny piece still stuck in the mechanism.
Could be waiting for manual feed or different size paper or envelope. Pressing the "go" button will force it to use loaded paper.
Other issues could also cause this "attention" light.
Imaging drum is empty or missing (Error 40204)
Light pattern
Description
The imaging drum is empty or missing. The imaging drum light is blinking, and then printer stops printing. An error 40204 is written to the event log. The printer cannot detect the imaging drum correctly.
Action
Imaging drum e-label reader is faulty (Error 10004)
Light pattern
Description
The imaging drum light is blinking, and then printer stops printing. An error 10004 is written to the event log. The imaging drum e-label reader is faulty and the printer cannot detect the imaging drum correctly.
Action
SOURCE: HP Laser Jet 1320. Orange light
The Amber light is designated as the "Ink Error" light. With regards to a Hewlett Packard printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Clean the cartridge and carriage contacts with a cotton swab moistened with water. If you have refilled the cartridges don't assume that they will still work. If cleaning doesn't help you may have a failed cartridge even if it is not refilled.
If you are getting a grinding noise, clean the carriage rod with alcohol and lubricate it with a few drops of Tri-Flow, available in 2 oz. squeeze bottles at cycle shops.
If I have helped please rate my post...I will always do my best to help
SOURCE: HP Laserjet Printer 2550n flashing orange light next to triangle
This is a link to HP for your Color Laserjet 2550n instruction manual. Look on pages 97 & 98.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00189910/c00189910.pdf
And for further troubleshooting, try this link.
http://h20499.www2.hp.com/gts/sparks/public/IPG_CLJ2550_All_toplevel_WhatDoYouNeedHelpWith_PUB_EN?lang=en&cc=US&product=Printer&series=na&subseries=na&prodTypeId=18972&prodSeriesId=388394
SOURCE: My printer has an orange light showing next to a
It the light is solid then the toner is low. If the light is blinking the toner cartridge is missing and has been removed
