Question about Scubapro MK11/R395 Regulator SCUBA Equipment
Hey guys, im confused... i want to buy my new diving gear and i have come to a conclusion between two packages... these are : Scubapro : 1st stage din/int Mk17/395 reg + Oct R295 + seac sub BCD (First) + pressure gauge. oR Mares regulator Rover 12 attack din/int + octopus Mares proton + seac sub BCD (first) + Mission 1 pressure gauge. Please! i need you help!!! The scubapro is priced abit more than the mares. but i really want to pick one from both. we live in a warm water enviromenet are we are planning to dive between 20- 50 meters. Thanks all.
Posted by callmeclay on
  • Anonymous Aug 20, 2010
    I would stay with one brand in your selections. This way you only have to go to one dealer to get the gear serviced. Look at the warranty options carefully. The differences can make a big difference in your bottom line after a few years. Traditionally Scubapro has cost a bit more, for their higher end regs, but offered free parts to the original purchaser if the reg is serviced annually, as it should be. The parts for a reg overhaul can run near $100 if you are paying for them out of pocket, so after a few years, the original cost is moot. Also, in my experience, you can likely find a Scubapro dealer just about anywhere you go. Not necessarily so for Mares.
Dan Jacobs
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 808 Answers
Denx7d could have not said it any better i have about 1300 dives on my gear and still in good shape and have annual service on my gear now i am a certified repair technician for scuba pro these regulators they sell are the best on the market hands down
Posted on May 16, 2014
3 Related Answers
Anonymous
  • 121 Answers
SOURCE: with inhalation there seemed to be a brief stop in
Is this reg new by any chance??
Or perchance it's due a good service?? Sounds like something is sticking inside..
Alternately, I had a similar problem with my mk25 just after I bought it. The dive center I was in were able to fix it overnight for me so I the weekend wouldn't be a washout and the said afterwards that the problem was one of the seals/valves inside that was a bit of a design flaw. They knew about it and had replacements on hand so it could be worth letting your local service center look at it and see what they think..
It's possible this is it too..
Posted on Oct 15, 2009
Testimonial: "Maybe thats the problem ? It is 3 years old with 60 dive and have just been to service, think they have to check it one more time. Thanks !"
Anonymous
  • 19 Answers
SOURCE: Anyone know where I can get a Scubapro repair
check here: http://www.frogkick.dk/manuals/scubapro/Manuals/
Posted on Jun 27, 2010
Anonymous
  • 19 Answers
SOURCE: I need to strip down my s555 regulator to find
Check here:
http://www.frogkick.dk/manuals/scubapro/Manuals/2.%20Stage/
May not have exactly your model, but something very very similar. Also, keep in mind, the second stage will free-flow as an "overpressure safety" if the first stage is malfunctioning. Check your intermediate pressure (should be ~150). If you can't do this, try your second stage on another first stage (any brand), and try another second stage on your first.
If it is for sure your second stage, check for proper adjustment of demand lever, bent/damaged demand lever or diaphragm plate, or damaged valve seat.
I have a 1997 Chrysler town & country van. It want shift out of 1st gear. I don't have the codes on hand that I was given.. But I remember the guy explaining that it was a shifter switch problem In the...
The solenoid package is mounted at the front of the transmission. You have to remove the transmission cooler lines and a sensor. Three bolts remove the package. Before removing it, clean all around it. Air works the best. A lot of dirt gets behind it, between the package and transmission. You absolutely can not get any dirt in the holes after you move the package. This will cause a jam in the pistons inside the transmission. Then it has to be pulled and cleaned. The package can run up to $300 at parts stores, shop around. Seen them new on ebay for half. DON"T buy a used one. The package has one plug on it, with a bolt in the center of it.
Jan 17, 2015 | 1997 Chrysler Town & Country
Computer Malfunction
Call scuba pro they can assist you with problem if they can not fix it over the phone send it to them for repair or replacement.
Apr 03, 2013 | Scubapro Subgear Xp-10 Computer 3 Gauge...
Problem E 6 comes up on my uwatec smart com
I have a smartcom very nice dive computer this issue can ONLY be repaired by scubapro themselves the smartcom is obsolete they will give you trade dollars toward a galleo or luna which are better dive computers
Feb 05, 2013 | Scubapro UWATEC Smart Com Console Dive...
I have been using my A700/mk25 for six month and recently it has been making a whislting noise when I inhale.
the whistle noise is some thing loose (torn o-ring) inside the second stage. this is covered under warranty. scuba pro offers a parts for life program which is no cost to you if 1st & 2nd stage with a computer are bought at one time. just pay service labor. the whistle noise will be repaired are replaced free under 1 year.
Dec 23, 2012 | Scubapro Mk25 & A700 High End Regulator By...
Check here:
Jan 18, 2010 | Scubapro Service Diagrams Scuba Regulator...
With inhalation there seemed to be a brief stop in the air stream and some resistance. This happens regardless of how my second stage is tuned. I have had two other divers to try it and they both felt it...
Sep 27, 2009 | Scubapro MK17/X650 Regulator SCUBA...
Possibly high intermediate pressure. slight second stage free flo
It is a HORRIBLE idea for you to dismantle your first stage. It should only be done by a trained technician because of how many small parts there are... now depending on your regulator you might have the ability to turn down the pressure... read the manual to find out if your reg has this adjustment capability.
May 14, 2009 | Scubapro MK17/X650 Regulator SCUBA...
Extreme loud sound on MK/25
did you check your bulletins from scuba pro ? depending on the actual year of mfg ( you can call scuba pro and give them serial number )
there was a retro fit kit made for the mk 25 first stage of you send me your email i will send the bulletin to you
other wise if you wew working from an earlier service guuide then you would notbe aware of the retro fit kits and pistons some of the earlier schematic will not show you that o ring that you were refering to
Jan 21, 2009 | Scubapro MK25/G250 Hp Regulator
I want to buy an e class but confused about that
It's trim options. Basically different trims available, styling packages, wheels/tire sizes-things like that. There is no real performance differences between them.
Nov 09, 2008 | 2008 Mercedes-Benz Mercedes Benz E Class
Scubapro MK11/R395 Regulator SCUBA Equipment Logo
301 people viewed this question
Top Scubapro Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Tom Chichester
Are you a Scubapro Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
