Siemens optiPoint 400 IP Phone Logo
Posted on Jan 21, 2010
How to access optipoint 410 config menu
I need to access the 410 config menu to change settings while the phone is on. currently i need to plug out the lan cable and change it that way.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1812
Points
Press 1, 0 & 3 at the same time, this can be quite awkward & may need several attempts to succeed, but it does work.
Anonymous
Level 1:
New Friend:
  • Posted on Mar 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1812
Points
My many phone is stuck and dead .
Change internal directory on optipoint 500
The extension name and extension number are set in the system programming. Use manager 'e' and change them in the station view. If you are swapping people around and want them to keep their extension numbers and names, you should re-patch the cables feeding to the wall sockets rather than change the programming (if you can).
6helpful
2answers
Cannot received mms picture
Menu - Settings - Configuration - Personal config. sett.:
MEdia Net
Account name: MEdia Net
Homepage: http://device.home
Use pref. access pt. : No
Access point settings
Proxy: Enabled
Proxy address: wireless.cingular.com
Proxy port: 80
Data bearer: Packet data
Bearer settings
Packet data acc. pt. : wap.cingular
Network type: IPv6
Authentication type: Normal
User name: [email protected]
My multimedia messages
Account name: My multimedia message
Server address: http://mmsc.cingular.com
Use pref. access pt.: No
Access point setttings
Proxy: Enabled
Proxy port: 8080
Bearer settings
Network type: IPv4
Menu - Messaging - Message settings - Multimedia messages - Configuration sett.
Configuration: Personal config.
Account: My multimedia message
Can Siemens optiPoint 500 phone be used at home
An "Optipoint 500" phone can not be used at home!
It is a digital phone, specifically designed for Siemens digital phone systems. Do not plug it in at home. That could damage the phone or may knock your phone line off.
However you can use a "Optipoint 500 IP" phone at home for voice over IP calls. But this would be connected into your broadband router and would connect via the web to your companys Siemens phone system.
1helpful
Features keys
To add an Extension Key, enter [*91] and choose “Repdial Key” from the menu. Enter an extension or group number and press the [ü] key.
1helpful
4answers
Gprs settings on bsnl postpaid 199 rental on nokia 3110c
well.. u need to contact BSNL customer service people, and they should send u the GPRS settings by sms, just save the settings and use them as your default config settings.
the other way would be to manually configure GPRS by manuallyin addint an access point and other settings, which will get complicated as you will have to manually copy them from other BSNL GPRS enabled phone..
best way is to contact customer service, and they will sms the settings to u..
Olympus Stylus 410
try to clean the pad using water damped cotton if you are techie, professional fix is needed if you're not.
74helpful
3answers
Changing the time on a siemens optipoint 500
here you go , follow this on your main phone to reset your time.
press sevice button ( top left )
press *95
press *95 again and press tick
press tick again
press right arrow key until you come to time
press tick key . then press *
enter time (hhmm) then tick key
press main service button and your done.
Top Siemens Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
