Question about Mitsubishi WS-55807 TV
The v chip locks up how do we remove this if dont have code for good on hd 1080 is there a code change to remove the original
  • Mitsubishi Master
  • 12,061 Answers
SETTING V-CHIP
This TV is fitted with a V-CHIP controller which provides you with channel viewing access controls
and restrictions. This function is to prevent your children from watching violence or sexual scenes
that you may choose to exclude.
Press the MENU button and press the SET + or – button to select the V-CHIP SET option,
then press the ENTER button.
Enter your password (4 digits) using the Direct channel selection buttons (0-9).
In the event of entering incorrect password press the RESET button. Then press the
ENTER button.
Enter the same password for confirmation, then press the ENTER button.
Press the SET + or – button to select the V-CHIP option.
Press the ENTER button to select the ON.
Press the SET + or – button to select the TV RATING or MOVIE RATING option. Press
the ENTER button.
Press the SET + or – button to select the desired rating for the applicable video or TV
channel. Press the ENTER button.
And to change or put in a new password:
NOTES:
• If you want to change password, follow steps 1 and 2 and select "CHANGE PASSWORD"
option then enter your new password.
• The V-Chip function is activated only on programs and tapes that have the rating signal.
• Once you block a program using the V-Chip function, the blocked program cannot be watched
based on the content of the show. When the program starts, the "INPUT PASSWORD" will
appear on the screen. When you want to release the V-Chip temporarily, enter the password.
If you change the channel or turn off the TV while the V-Chip function was temporarily released,
the original setting will be resumed. If you return to the channel you were watching you must
re-enter your password to temporarily release your V-Chip function again.
• When you watch the TV from the cable box or the VCR with the RF Modulator, then you release
the V-Chip temporarily, the V-Chip setting will not be resumed until you turn off the TV. The
TV channel is not used in this case.
• When changing the channel with the cable box or the VCR, approximately 10 seconds will
pass until the program appears.
Hope this helps.
Posted on Jan 21, 2010
My 55 inch Mitsubishi hd 1080 has white spots on screen
it is dmd chip issue. dirty or goes bad.
firstly, try to clean DMD chip, if no helpful, you have to replace it by a new one.
good luck for you
Aug 23, 2014 | Televison & Video
Como agarro el pasword para desbloquear mitsubishi hd.1080
change empom memory chip 8 pins 4pins on one side go to ground
the other side first pin 1 sould have 5 or 3.5 volts .. this is the memory that all configuration go like ch color pass4words est. good luck ... frank
Dec 12, 2012 | Mitsubishi WD Televison & Video
I locked the front button on me 50 inch tv its a mitsubishi 1080 hd series and dont have the remote i do i reset the thing
the only way to reset this thing is to bring new remote for this model & unlock with it. get the original remote from authorized service station.
Aug 19, 2011 | Mitsubishi VS-50111 50" Rear Projection...
Can not turn off the vchip channel lock on hd 1080
hello try this Bypassing the V-Chip Lock
After you set the lock, you need your
passcode to view a V-Chip locked program,
view the locked TV, cancel the lock, or enter
the V-Chip lock menus.
If you forget your passcode, you can
view the locked TV without entering your
passcode. This is done by pressing the
number 9 and QV buttons on the remote
TV control at the same time, when your
password is requested. This process
temporarily unlocks the TV.
When entering the V-Chip Lock menu, this
process deletes your old passcode and
prompts you to enter a new passcode. good luck
regards
shaun
May 14, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Just fixed the convergence chip problem.$534.00. Now 720p and 1080 1 signals are showing double images and colors. Also the componentinput #2 is showing double images on any format
many of these sets need the convergence adjusted in the 480 and the 1080 separate-- the set most likely if looks good in 480 needs to be adjusted with the original remote in the 1080 mode.
Whoever charged you 534 got you---if you did it yourself you paid way too much--with 1080 signal--enter convergence mode and try to adjust in customer menu--if 480 is ok---it needs to be adjusted in the hd mode.
SD TECH
Oct 31, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Unlock parental control
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Apr 01, 2009 | Quasar SP-2722 27" TV
Mitsubishi 1080 rear proj. tv
I can help you unlock your Mitsubishi HDTV V-Chip, but you will need an 'original' Mitsubishi remote control for the fix to work.
I hope that helps.
Feb 18, 2009 | Mitsubishi WS-65515 65" TV
Can i convert sony bravia 46" V-300A HD RADDY INTO FULL HD 1080P
no you cannot change the HD to 1080p . if you could why would there be any 1080p sales???? most people cant see the differance between 720 and 1080p and most sat./and cable HD is only 720p anyway
Jan 31, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I need the V-Chip code for an HD 1080 series TV.
delete characters by pressing cancel for each character
Dec 14, 2008 | Mitsubishi WS-55807 TV
My sony model is dsc-h7 full hd 1080 15x optical zoom 8.1 megapiksel
I CHECKED SOME DIFFERENT SITES FOR SOLUTIONS AND FOUND ONE THAT PROBABLY MEANS MORE TO YOU THAT ME, NOT BEING FAMILIAR WITH YOUR CAMERA. IT STATED THAT TO RESET THE ERROR ONE NEEDED TO GO TO THE CLOCK SET MENU, TURN OFF THE CAMERA AND THEN REMOVE THE MEMORY CARD. THIS WAS SUPPOSE TO RESET THE ERROR CODE. I HOPE THIS HELPS YOU. WISH I HAD ALITTLE MORE TO GIVE YOU, BUT IF THE PROBLEM IS STILL THERE REPLY AND I'LL SEE WHAT ELSE I CAN FIND. GOOD LUCK!
ARCLIGHT1217
Oct 17, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Mitsubishi WS-55807 TV Logo
336 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
