Question about Durabrand DU1301 TV
Directv tech support told me to turn off the V-chip on my Sony Bravia TV to program the tv to my Directv remote. How?
  • Anonymous Jan 23, 2010
    Reading the answers from Silverdragon and 1 Alexh was like reading factory manuals. Thanks! Despite Directv's V-chip instructions (and Silverdragon's suggestions on how to do it) the V-chip being turned off didn't help to program the remote. I talked with the local Radio Shack manager and he told me that Directv and Dish remotes won't work with the newer flat screen TV's. He said he has to use 2 remotes with his flat screen. Is he right??
    Thanks,
    molysyd
  • 484 Answers
While he did specify DirectTV, Silverdragon just gave a most impressive write-up on this process. The fact is, there should be no difference between doing this with Cable or DirectTV.
The process should be exactly the same.
Follow the above from Silverdragon on disabling the V-Chip temporarily, doing what needs to be done with the settings, then re-enabling the V-Chip.
Perhaps the only thing that may be missing is that you should use the remote control for the Sony Bravia TV to do this process, rather than any other remote control. That way, you are working directly with the TV itself, and have complete control.
Otherwise, you will be working through an "emulator" or a remote that translates from the universal control to the TV control.
When doing something of this detail, use the specific TV control to get it done.
Excellent work, Silverdragon!
Molysyd, you are in great hands!
-a.
Posted on Jan 22, 2010
  • 12,061 Answers
SETTING V-CHIP
This TV is fitted with a V-CHIP controller which provides you with channel viewing access controls
and restrictions. This function is to prevent your children from watching violence or sexual scenes
that you may choose to exclude.
Press the MENU button and press the SET + or – button to select the V-CHIP SET option,
then press the ENTER button.
Enter your password (4 digits) using the Direct channel selection buttons (0-9).
In the event of entering incorrect password press the RESET button. Then press the
ENTER button.
Enter the same password for confirmation, then press the ENTER button.
Press the SET + or – button to select the V-CHIP option.
Press the ENTER button to select the ON.
Press the SET + or – button to select the TV RATING or MOVIE RATING option. Press
the ENTER button.
Press the SET + or – button to select the desired rating for the applicable video or TV
channel. Press the ENTER button.
And to change or put in a new password:
NOTES:
• If you want to change password, follow steps 1 and 2 and select "CHANGE PASSWORD"
option then enter your new password.
• The V-Chip function is activated only on programs and tapes that have the rating signal.
• Once you block a program using the V-Chip function, the blocked program cannot be watched
based on the content of the show. When the program starts, the "INPUT PASSWORD" will
appear on the screen. When you want to release the V-Chip temporarily, enter the password.
If you change the channel or turn off the TV while the V-Chip function was temporarily released,
the original setting will be resumed. If you return to the channel you were watching you must
re-enter your password to temporarily release your V-Chip function again.
• When you watch the TV from the cable box or the VCR with the RF Modulator, then you release
the V-Chip temporarily, the V-Chip setting will not be resumed until you turn off the TV. The
TV channel is not used in this case.
• When changing the channel with the cable box or the VCR, approximately 10 seconds will
pass until the program appears.
Posted on Jan 21, 2010
I have a new RC65 remote, Sony Bravia KDL-46XBR4, and Directv receiver HR 21-200. I have programmed the remote in the TV position and can control the television. I then switch over to the directv symbol...
reset the code again go to www. remotecodelist.com or remotes.com
tight the spring contacts very well with long pliers, and clean it
replace new batteries with the same type, alkaline, and FULL Charge.
download and fix it.
God bless you
Oct 12, 2012 | New Directv Rc-65 Universal Remote Contron...
Program directv remote
It may or may not program for the sony set, Sony uses many different remote codes.
Sep 01, 2012 | Sony Bravia XBR KDL-40XBR6 40-Inch 1080p...
Rc65x not working with sony bravia
Direct TV rc65x code for Sony Bravia is 10000
Setup Instructions
  1. Set the "Mode Switch" to Device 1 (in the case of the rc65x set on TV).
  2. Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  3. Enter the 5 digit Code above.
  4. Try your new code and tell us how it worked!
    (It worked perfectly for our Sony Bravia using our rc65x remote)
    & Goodluck!
    http://www.ezremote.com/setupcodehelp/DTV2/dtv.html?product=DIRECTTVRC65SW2009#search
Jul 25, 2012 | Directv RC65X Universal Remote Control
Sony Bravia LCD No picture, no sound I can pull up direct tv guide and all menu's but no pic or sound.
have you check other sources connected to the tv? if you can pull up directv box menu then tv is good. issue with directv box. try to unplug directv box for 1 min
Oct 18, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
DIRECTV Universal Remote Remote Control: need direct tv codes for magnavox tv. codes listed...
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
May 17, 2010 | Universal Remote Control DIRECTV Universal...
Problems programming DVR remote to TV
If your DirecTV remote is in SAT mode and the power button isn't turning the receiver on and off, you will likely need a new remote. There isn't suppose to be any trick to getting the power button on a remote to work. However, only DirecTV tech support can confirm this. I would give them a call right away.
Jul 12, 2009 | Philips Televison & Video
I have a new Sony Bravia 46inch LCD tv with direct TV remote RC64R, what code can I use to get my remote to work? I've tried all the codes in the book.
i have a 46 inch sony bravia that i bought in 2007. recently i have noticed that the screen is showing horizontal lines (purple?) about that come and go. any advice would be greatly appreciated
Jul 11, 2009 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Program remote for sony ht-5100-d
Use your Directv remote. Use code 10812, remember to program it to change tv inputs also. then program the same remote to control volume on your Sony receiver. Go to the menu on the directv box and follow the onscreen instructions.
Apr 24, 2009 | Sony HT-5100D System
Directv remote won't turn on tv or control volume
I am a installer and 10154 works wth every Sanyo TV whether it is HDTV or a SDTV that I have encountered. Try this code using same method above but do not enter 911 but rather 10154. It should work!
Apr 02, 2009 | Directv RC23 Remote Control
Cant program directtv remote to sony tv
See if this web sight helps in your problem
Good Luck and have a great day.
RCA Universal Remote Control-Programming Codes
Ed
NC Electronic
Mills, Wyoming
Jan 25, 2008 | RCA RCR311B Remote Control
Durabrand DU1301 TV Logo
286 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
