Seems to be a dns issue. At least that's what xbox live said. Tried firefox on my pc. Unable to load pages. Ran dos. Released and renewed ip. Flushed dns. These did nothing. Not sure what to do. The router seems like it's functioning properly but as mentioned above, the modem just flashes the three lights
SOURCE: Thomson SpeedTouch 576 wireless modem router
192.168.1.1 is a common/default network router connection. Thompson use a different connection of 192.168.1.254 Don't forget to configure XBOX360 and PS3 through there too. You can even find your WEP key just incase you've forgotten it. If you use http://192.168.1.254 in Internet Explorer you may be greeted with a box asking for username and password. Both username and password are " admin " in lower-case. Then to retrieve the WEP key click on HOME NETWORK. You'll see your Wireless network and Ethernet network. Beside the WIRELESS you should see WLAN: XXXXXXX (54Mbps) click on that. In the top right just under SPEEDTOUCH you will see OVERVIEW | DETAILS | CONFIGURE | HELP If you click on DETAILS down near the bottom is your WEP key. Hope this helps anyone out there.
SOURCE: Port Forward a RCA Thomson DCM305R
it just a cable modem. I don't think it does have firewall. It won't block anything.
- Laxman
SOURCE: how to flash my dcm425 cable modem
Message
Flashing - flashes to indicate unread email (only if ISP enables this feature)
Off - no email messages pending
Cable Activity
Flashing - indicates data traffic; modem is in use
Off - indicates no current data traffic
Cable Link
On - cable modem is connected to the network
Flashing - cable modem is attempting to connect to the network
Off - cable modem not connected to the network
PC Link
On - PC is detected but no current activity
Flashing - activity between PC and modem
Off - no computer detected or modem is in standby
Internet
On - If this and the Cable Link light are steady then the modem is connected
Flashing - modem is searching for a downstream signal
Off - power is not supplied to the modem or modem is
only ISP provider can help you on this one
SOURCE: not getting an internet connection. The pc link
Have you tried removing the AC power from the modem for at least 10 seconds, and then re-applying power? This will cause your ISP to reconnect and reassign your IP address. Then your modem should allow you to connect.
SOURCE: The internet light is flashing on the rca dcm425 i
My RCA DCM425C from Comcast had the same problem when I came home Saturday, 11/14/09 (coincidentally the same day you posted). Had been working fine - cable TV still works fine including On Demand, etc. The Internet light was blinking. Occasionally I'd see it try to work from one light to three or four, but it always came back to one. Called Comcast, they said their side showed "no signal". Sent out a tech today. He replaced the cable modem, reprovisioned it (I guess if I had a backup ready I could have done the provisioning over the phone maybe?)), everything's great. Lasted about a year and a half. When I logged in via http://192.168.100.1, it said it was still in Step 1 of 5 ("Tuning"), and the logs showed a whole bunch of errors on Saturday that stopped after that. Diagnostics would always freeze the built-in web server and require reboot.
