Hi, can somebody please explain to me me why, on a hardwired network with 5+ PC's, I can print from a Canon MF6550 from any PC on the network but I can only scan from one of the PC's? How do I set it up so that I can scan from ALL computers on the network?
Thanks!
SOURCE: Canon Image class MF6550
contact them, ask for a refund or a replacemnt. This is the first time Im seeing a company use the same model number in more than one product. Im very sorry.
SOURCE: Will not print
The Simple Network Configuration capabilities of
Mac OS® X can only find devices in the local network segment. If your
Macintosh® and devices are not in the same network segment or are
connected via a router, you cannot use the Simple Network Configuration
capabilities of Mac OS® X.
In these cases, I recommend you use IP printing.
SOURCE: CANON IMAGE CLASS MF6550 PRINTS BLANK PAGES
the lase unit windows is block. It has a metal windows that for some reason sometimes stay clouse. just but a tape to hold it up or remove LSU and take out that metal part.
SOURCE: my canon ImageClass MF6550 only make blank copies
Here is an easier solution...nothing to break or bend...When you remove the toner out, you will see the metal grill that is above the toner. Point your flashlight to to the right hand side of the metal grill, you will see a black plastic level within the metal grill. At this point use a small/medium screwdriver and lightly poke upper on the black plaster level, you should hear something drop. That is it, place back the toner and you should be able to print again.
