Question about GE Dishwashers
GE Potscrubber disher - water leaks out while filling
GE Potscrubber disher - when the water comes in sometimes (very intermittently) the water overflows out all over the floor. There seems to be some sort of switch with a debris gaurd in front left side in tray bottom, and if I bang on that it seems to work again... but every so often it spills all over the floor again. Is thaty a float switch of some sort and can I replace it?
Posted by racfelmel on
Anonymous
    New Friend:
I would try removing the cover and make sure the float isn't sticking. On mine the float pushes on a rod that goes through the tub to a micro switch. When you hit it, it probably frees it up for a while. Hope that helps.
Posted on Jan 21, 2010
My GE Potscrubber Model GSD2230Z04WW is not dissolving the soap. I have already replaced the water inlet valve.
Check your wash arms, and make sure the holes are not plugged. Also make sure they are free to turn. Next,remove the toe-kick panel, and look for leaks or signs of leakage. Sometimes (especially if your tile floor doesn't go all the way back), dishwashers will leak most of their water out and you never know it! Other simpler things is to make sure you are not blocking the soap dispenser with large pans or plates.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Feb 17, 2015 | GE Dishwashers
Ge potscrubber 800
GE Potscubber 800
Issue: No water.
What works:
- Dishwasher appears to operate normally, just does not call water.
- Water valve works
Suspected:
- Float / float switch
Needed:
How to test float switch
Jun 01, 2013 | GE 24 in. GSD3400G Built-in Dishwasher
GE potscrubber 1200. Fills only partway with water. Holding down float switch makes no difference. Is there another water level control somewhere?
Hi... No there is no another control ....The main control board time fills it!! So that means you have a bad valve ....If I were you I would get a new water valve
Apr 07, 2011 | GE Dishwashers
When I turn on the GE PotScrubber dishwasher with water, water is leaking out from disher please advise. According from one repair guy, it is related to pump issue please adivse
first try to look and see where the water is coming from,,,the bottom of the unit,,,,or the front of the unit...remember the door has a seal all the way around it and it has to seal correct and make sure the latch is all the way in lock postion
Feb 19, 2011 | Maytag Dishwasher
Does not cleans dishes
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 11, 2009 | GE Dishwashers
My disher washer is leaking water i cleared the drain the best i could
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
23456arhgdhj
Oct 12, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Intermittent ice cubes
is it leaking on floor behind refrigerator? cracked water line from fill valve by compressor?
Aug 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Potscrubber Dishwasher Stuck on Cycles
Could be a defective cycle timer
Jan 30, 2018 | GE Dishwashers
GE potscrubber 700
upc leaks when dishwasher is emptying
May 12, 2008 | GE Dishwashers
Dishwasher
GE 720 Potscrubber I started with the water puddling in bottom now it progressed to leaking on the floor. I had a repair guy come to my home yesterday and he says a broken seal and my total cost to replace seal and labor is $165 plus tax.
What is the life expectancy? He did not sound too promising about the future of my dishwasher and said he is certain there will be another repair need shortly something related to the water saturating an area underneath the dishwasher?
He reccomended I call Sears and replace with a Whirlpool product. He claimed he put his kids thru college repairing GE products. My husband wants to repair and I dont because of fear of spending more money!
Jun 18, 2007 | GE 24 in. GSD2600GBB Built-in Dishwasher
Dishwashers Logo
807 people viewed this question
Top GE Dishwashers Experts
Mike
Nathan Van Boven
Nathan Van Boven
Bill Johnson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
