Take out your ice bin the look in the back of the freezer and ytou will see a small hole with a plastic sqaure actuator.hold the door switch closed and make sure the unit is selected for cubed ice then try and dispence ice if the swaure plastic acuator moves up it is working fine it shoeld drop down when you release the dispencer arm.if it dropps back down then make sure that the metal bail arm is properly inserted into the hole in the auger case when that actuator moves up this opens the small plastic door on the ice bin to allow subed ice to come out.make sure there is no ice build up on the ice bin that would stop the trap door from opening.good luck with you fridge i hope this helps you out,let me know how thing s go for you.
Testimonial: "Good idea, I'll try and see if helps. Thanks."
