Sony KV-36XBR250 TV Logo
Question about Sony KV-36XBR250 TV
No picture or sound when powered up. Red Standby light flashes continually. My Sony KV 36 XBR250 Wega Trinitron XBR is about 10 years old and has worked perfectly up to this point. What could be the problem?
Posted by capability_b on
Anonymous
    New Friend:
Did you get your set fixed or did you replace it? My same set did the same thing. Turned it off for 2-3hrs after watching it and when I tried to power it up- nothing but the sound it would normally make just before the major power up, sort of a relay click sound. No picture or sound but the red light blinks non-stop.
Posted on Jun 05, 2010
We have an 11 yer old sony wega KV-32FV15 We lost picture and sound. Power on swirtch activates the standby red light which just continues to blink (no Sound no Picture0 We know we have the power plug...
the tv is defected needs to be repaired..have a tech repair your tv.the problem is in the power supply or horizontal circuit.could be any thing in one on those circuit.good luck.
2002 36" Sony Trinitron XBR High Def TV. When you
Your power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem..
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
1helpful
Sony triniton,no sound or picture,flashing red light blinking!
the main problem of your tv set is the main power or what u call the regulator.the red light blinking it means your tv set is on standby mode.
Sony trinitron kv-36fv26 (2000) tv wont show picture
Trires unplug,replug about an hour later see if it reset it self.Not take to the shop the two power ICs help the power it dead.Need it replaced.
1helpful
Picture wont come on screen
this problem is in the power supply.the red lights indicate as the standby mode.
No picture, Standby blinks then goes out
Sony Trinitron XBR
Problem/ Standby Flashes Power button
SONY 36 XBR SOUND BUT NO PICTURE
posible solution is adjust the screen to low.also check the trimer if it is working.check the resistor in the heater line...weng
Top Sony Televison & Video Experts
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
