Question about Microsoft Xbox 360 Console
Screen on all games is blurry. Just started
Screen on all games is blurry. Just started happening. If i leave it off for awhile it will be fine for 5 minutes or so, then back to blurry (almost black and white) whats wrong with it
Posted by josiahbradbu on
Anonymous
    New Friend:
    Problem Solver:
  • 5 Answers
Make sure its not your tv.there might be something wrong with your xbox or you did something in the options menu that messed it up
Posted on Jan 20, 2010
I just bought CoD Mw2, the installation went without any problems, but whenever I try to start the game; I get to the start menu and then the screen freezes, this happens to both single- and multiplayer....
Yes. This happens everytime. Here's a secret/glitch/whatever: when it starts, dont click anything. wait for the game to load up to the main menu. For example in Single player: just leave the keyboard/mouse. wait for all the short clips to play. after you get to the main menu (Spec Ops; Campaign; Multiplayer)Use your arrow keys to choose which. For example: I want spec ops. I just hit the left arrow key once. It might still freeze, but after awhile, it will be highlighted/selected/whatever. hit enter. then wait for it to load. then keep repeating these steps on what level/difficulty. then after you play a game, everything will go back to normal unless you quit again. That's all. Plz rate me.
Jan 06, 2010 | Activision Call of Duty 4 Modern Warfare...
When I was playing a Game Cube game on my wii. Somthing popped up saying if I wanted to switch to some mode. I Clicked yes accidently and now when I turn on my wii It Doesnt show anything but a Blurry...
It sounds like you may have switched some video setting that your TV can't handle. Try removing the battery and leave it out for awhile (hour) and see if that helps.The battry is in small bay on the botton of the wii and is held in with 1 small screw. Good Luck
Nov 23, 2009 | Nintendo Wii Console
Lines and blurry screen
hi, sounds like u need some solder joints re-worked (probably quite a few for a set that old, but your right it`s a great set), price varies by region greatly, I`m in central florida we would charge 75 for service call & 95-125.00 for labor depending on how long it takes to do the solder rework, hope this answers your question, get it fixed it`s waaay better than the new hd (ha ha ha) sets, video-tek
Jun 02, 2009 | Hitachi Televison & Video
Cant see anything
this is a fairly old model!
the lcd optic engine requires cleaning as the mirrors inside will be dusty,also from what u have mentioned,it appears that the polarising filters inside are damged.pl check if the image that u see is spotless.if it has permamnent patches of green or red or yellow, then the polarising filters are damged & u need to change them!
Dec 28, 2008 | Philips LC 4500 projector lamp Projector...
Radeon 9550
Usually with that card, that condition happen if there isn't enough video memory to process the graphics.  Does the memory card memory settings you are using acceptable to the game you are playing?
Oct 22, 2008 | ATI RADEON 9550 Graphic Card
Blank white screen
Try using some alcohol to clean the contacts of the card and leave some on and reinsert a few times - leave to evaporate and try again - sounds like dirty contacts!
Sep 16, 2008 | Nintendo DS Lite Console
Bottom touch screen blurry
it happens if there is moist or dust or sand inside the ds so breath INWARDS through the L or R buttons but dont pull too hard but **** as much as you can until it becomes alright plus keep doing it ... it took me 10 mins to get it right
Jan 05, 2008 | Nintendo DS Console
Blue screen of death on a tv??
this could be three differnt things
1. the crt itself could be bad
2.the vertical ic on the crt board
3. the focus pack or focus block
Sep 19, 2007 | Sony KP-53V45 53" Rear Projection...
Blurry Screen
ok your problem is the RGB section maybe crack soldered at the RGB try to resoldered it! you seen that at the back of the picture tube they have small board attach at the neck... resoldred all small part, and transistor drivers!!!
Nov 13, 2006 | Jensen TS2750J TV
Microsoft Xbox 360 Console Logo
149 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
James Bradburn
James Bradburn
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
