I have (2) sets of plug type wire (red and white) 2 each end
I have a stero receiver with tuner, CD/Tape 1 and Tape 2 The system
is old but works well. The equalizer is a JVC 66SEA
I imagine Tape 2 has a corresponding switch on the front panel of the receiver to monitor it.
The rear panel Tape 2 conenctor will look something like Record (Out) / Play (In). Similarly, on the EQ will be an RCA pair of connectors something like Preamp In / Amp Out.
Run a pair from the Ins of one device to the Outs of the other. Select Tape 2 on the receiver to hear the effects of its actions.
The EQ will probably have a switch that selects monitoring the Line (signal from the receiver) or Tape (attached to the EQ). The EQ will have its own Tape 1 (maybe 2) for connection of Tape Deck(s) or other processor(s). On its front panel will be controls to monitor it (them) and for placing the EQ logically in front of (Record) or behind (Playback) those devices.
Word of caution: until you have this all connected exactly right and are comfortable with how it interacts with your recever, ALWAY TURN YOUR VOLUME DOWN TO A SAFE LOW SETTING, prior to selecting or deselecting any Tape Monitor. Whatever you do, don't run the volume up in frustration because you can't hear the desired program and then suddenly flip the right switch only to blow up your speakers from the sudden appearance of LOUD music.
