Hi I have a Candy GO482, half way through the cycle its stops and all the lights on the front start flashing, it also doesnt drain. I have checked for blockages and there is none that I can see. Could it be electrical?
Hi all I have a candy bianaca washer dryer. When I switch it on it says welcome amd then shows long numbers across the screen. Wont let me select a wash or anything. Does its own cycle when turned on then lights continuously flash and doesn't do anything. Please help
Try unplugging it for 10 minutes and press the start button while it is unplugged and that usually resets the system. If that does not work then you have a board or drain problem.
first does the water drain in the machine or stays if so it can be your pump that sucks the water out or cloged check, next if its electronical screen it could be screen problem ,or even door lock somtime s pops half way will need to be change ,check step by step,, if helpful plz rate.
found the problem,unplug machine pull out remove back cover screws look in side machine,there is a black pipe on right hand side bottom of machine,that is the drain pipe to the pump,remove jublie clips and check for blockages,mine was blocked refit cover and put machine on normal cycle to clean,
