Question about Rolex Datejust SS
1990 Lady President (Datejust) with quickset date
The date begins changing a little after 12am but finishes changing at 3am; if I go backwards, it begins changing back at 12am but finishes changing at 9pm. I was told some change quickly at 12am and some don't - watch is keeping perfect time. Is this all normal?
Posted by Quart311 on
Arturs Kalnins
  • 2,338 Answers
This is normal and will not affect time keeping at all.
Posted on Jan 20, 2010
My watch is changing date at 2 am instead of at midnight, i have tried rechanging it manually, but still each day at 2 am it changes the day again. Why it not change at 12am O'clock what I can do pls
Thread: Tag Heuer Carrera changes its date at 3:00 am instead of ...
forums.watchuseek.com > Forum > Watch Brands > TAG Heuer
Jan 1, 2012 - 6 posts - ‎3 authors
The watch used change the date, as it should, at midnight but I just noticed last night that it now waits until 3:00 am... Does anyone have any ideas. ... Join Date: Jan 2012; Posts: 2 ... Changing the date on an automatic watch - Watchuseek ...
Mar 2, 2015
Damage of changing date at midnight on automatics ...
Oct 18, 2013
Setting the date destroys the watch? - Watchuseek, The ...
Sep 8, 2010
Thread: Does setting date between 9pm and 3am damage ...
Jun 6, 2010
More results from forums.watchuseek.com
How do analog watches know to change the date at ... - Quora
https://www.quora.com/How-do-analog-watches-know-to-change-the... QuoraThere is a gear within an analog watch that is used to change the date at the appropriate time. The gear ... Watches: What is a fair price for a authentic 1970's vintage "McQueen" Rolex Explorer II? Why does the day start at midnight?
Jan 21, 2016 | Watches
Can not set the date and day
I assume you are talking about a day-date Timex. Timex watches do have a quickset feature meaning the day and date can be set without having to simply advance the time by 24 hours to adjust the Day-Date. Not all watches have a quickset, but I'm sure your Timex does. Unscrew the crown from the stem by turning it counter clockwise until it is free from the threads. At this point pull the crown all the way out so that you can adjust the time. That's position 2 the quickset is in position 1 but the tricky part is getting the crown in the proper position to engage the quickset. Push the crown in very slowly while turning once you see the day or date window advance stop turning you are in position 1. Day and date can be set in this position by turning the crown in either direction. If your watch does not have a quickset or you cannot figure out how to engage it you must set the date by advancing the time forward 24 hours. This will make the date window advance by one day. Once the right date is displayed turn the time backwards 24 hours and this will cause the day window to move without affecting the date window. And that's all there is to it.
Dec 31, 2013 | Watches
How do u set the date on a datejust
on 1570 movements there is no quickset feature therefore you must turn the hour hand 24 hours to change the date but 3035 and other later movements equipped with quickset wheel and if you pull out the winding crown you can change the date.
Dec 27, 2010 | Rolex Datejust SS
Set time by moving it backwards, now doesn't tick.
Try setting it by moving it forward till the date changes twice and manually wind it about 40 turns. NEVER adjust the date between 7PM and 2AM as it can damage the watch.
Apr 14, 2010 | Rolex Datejust SS
Day/Date change
The date on mechanical and automatic watches change normally between 2-4am because this is normally when people sleep. It is not broken or in need of overhaul. It has to change sometime and that is what they have tradionally used as a time for the date to change. Also remember it is normal for an automatic or mechanical watch to loose or gain time friction is the culprit here since the gears do mesh with each other.
Fine watches like Rolex and Omega are beautiful watches but expensive to have cleaned. It should be cleaned about every 10 years or if it starts to loose a lot of time.
Incidently most agree that the Omega speedmaster manual wind (The watch that went to the Moon) is the most accurate of the bunch and is very sought after by collectors!
Apr 10, 2010 | Guess Dress Bracelet 87000L1 Watch for...
Oyster Datejust White Gold RX579 Ladies - faux
Pull the clasp where the Rolex crown is. It may be quite stubborn/stiff.
Aug 12, 2009 | Rolex Day-Date President 118239 Wristwatch
My date just will not set, it clicks two times but doesn't move
it's time for a overhaul and cleaning...the stem may be worn out. Rolexs need this service about every 10 years.
Jan 18, 2009 | Rolex Day-Date President 118238 Wristwatch
Setting the date on my rolex president day/date watch
if all else fales, you are probably in need of a service.
Jan 01, 2009 | Rolex Day-Date President 118238 Wristwatch
Rolex oyster perpetual datejust time/date setting instructions
Unscrew the crown pull out the crown to the first position, One click and rotate the crown clockwise. This is for Quick Set models
For non quickset
Dec 30, 2008 | Bulova Watch
Rolex datejust
What you have is an older model Datejust -- or at least an older model movement. During the 1950s, many Rolex Datejust models had an alternating red/black date wheel. Tudor (Rolex's second brand) also had movements with the same red/black date wheel.
BTW, those watches are becoming more and more collectible. Sounds like you may have a nice classic on your wrist! :-)
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
May 19, 2008 | Rolex Datejust SS
Rolex Datejust SS Logo
199 people viewed this question
Top Rolex Watches Experts
Bruce Robin
Janelle Schoonover
Janelle Schoonover
Are you a Rolex Watch Expert? Answer questions, earn points and help others
