I recently purchased a hotpoint oven model 481012GX, which came with a fitted plug, I thought this model had to be hard wired?
If i bought a single oven with a three wire cable coming out the back with no plug, which i know is meant to be hard wired, are you saying i could fit a plug to this and plug it into a normal 13amp socket, reason i ask i ahve an oven which has packed in and it plugs into the wall at the back, if i fitted a plug onto the cable from a single oven below 3kw then are you saying i can do this?
Posted on Feb 16, 2010
If it is a single oven, then it can be used from a normal 13 amp socket.
It only needs to be hard wired if it is a double oven or one with integrated hotplates.
If you are not sure, check the wattage rating, if it is less than 3kw, then it is safe to use from a socket.
Hope this helps.
Posted on Jan 20, 2010
Mar 04, 2014 | Hotpoint SY36 Style Line Stainless Steel...
Jan 18, 2014 | Hotpoint SY36 Style Line Stainless Steel...
Oct 10, 2017 | Ovens
Jul 19, 2011 | Hotpoint Ovens
Jun 22, 2011 | Ovens
Dec 09, 2010 | Hotpoint Ovens
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Oct 14, 2010 | Ovens
Jan 12, 2009 | Hotpoint SY36 Style Line Stainless Steel...
Jun 08, 2008 | Kenmore 47834 / 47832 / 47839 Electric...
833 people viewed this question
