Question about Canon imageCLASS MF4150 All-In-One Laser Printer
My Canon MFP4150 cannot send international faxes. I keep getting error message 0091 : error during tx. Please advise a solution.
Posted by paddyyg on
  • Anonymous Mar 17, 2014
    error 0091 During TX
mukhtar21 shaikh
    President:
  • Canon Master
  • 2,022 Answers
Make sure the the phone line which you using having ISD calling facility in dialing 1 st you try that no by dialing with the normal phone.
Posted on Jan 20, 2010
How do i get a fax confirmation to print?
Press function then data registration and set/ok.It will say user settings,press the arrow down to get report settings,press set/ok,it will say tx report press set/ok and use the arrows to get output yes,press set/ok and stop!It will print one after every fax u send!Enjoy!
Apr 29, 2010 | Canon FAXPHONE L80 Laser
How do I change the Baud rate on a canon f80 fax
To set the receive speed
Change RX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (RX or send) speed if this message appears frequently on the LCD.
  1. On the operator panel, press <Menu>.
  2. Press the left '<' or right '>' arrow repeatedly until [USER DATA] appears.
  3. Press [Set].
  4. Press the right arrow repeatedly until [FAX SETTINGS] appears.
  5. Press [Set].
  6. Press the right arrow repeatedly until [RX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [RX START SPEED] appears.
  9. Press [Set].
    1. The factory default RX (send) Speed is 33600 bps.
    2. You can select from the following RX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable RX Speed.
  11. Press <Set>.
  12. Press <Stop> to return to standby mode.
To Set the Send Speed
Change TX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (TX or send) speed if this message appears frequently on the LCD.
  3. Press [Set].
  5. Press [Set].
  6. Press the right arrow repeatedly until [TX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [TX START SPEED] appears.
  9. Press [Set].
    1. The factory default TX (send) Speed is 33600 bps.
    2. You can select from the following TX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable TX Speed.
You can download a copy of the user manual for the F80 at
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=7175
Please make sure to rate this solution. Thanks.
  1. Press <Set>.
Apr 29, 2010 | Canon MultiPASS F80 All-In-One InkJet...
L220 Cannon Fax tx function was not completed
It's possible you're not dialing the country's calling code or not dialing the correct sequence for international calling. To place a call out of the U.S. dial: "011 - country code - city code - number" The country code for Poland is 48. The link below contains the city codes for Poland which you may not have. Best of luck and I hope this solves your problem. Thank you for using Fixya and please remember to return to rate this answer.
International Calling Codes
Nov 26, 2009 | Canon ImageRunner 2020i Copier
Fax error message = TX cancelled:RX fax info mismatch???? Cannot send fax - How do I fix this error - Not all faxes return this message
Two Issues:
1. The Transmission Speed of the MX860 may be too fast.
Solution: on FAX Menu go to Settings>Device Settings>FAX Settings>Transmission Settings >"TX start speed" and change to 14400 or lower (14400 worked for me).
2. The recipient FAX machine may be receiving by a different number than the one you dial. This may occur if you dial a free-calling no.
Solution: Go to Transmission Settings as above>"Check RX fax info" and turn it to OFF. This disables the mismatch issue.
Hope this helps. aknz
Jul 31, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
"TX function was not completed" on my MP730
Probably some interference on your phone line...try a line filter.
Mar 26, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
OUTGOING FAX ERROR CODE: NG
I can advise you on the 'memory full' problem, mate.
If you get a MEMORY FULL message while scanning the first page of a fax, press Stop to cancel the scan. If you get a MEMORY FULL message while scanning in a subsequent page, you’ll have the option to press Start to transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending on your typical faxes, MEMORY FULL errors can occur frequently. If this happens, change the Memory Transmission setting back to OFF.
To do this:
Press Function/Set, 3, 9.
This should take you to MEMORY TX
and MEMORY TX: ON?
Then press either the left or the right arrow (< or >) to switch on or off, and press Function/Set.
For the next fax transmission only, press < or > to select
NEXT FAX ONLY and press Function/Set.
This will mean you don't add any more to the memory and may be able to send faxes. There is a possibility that you will only be able to fax using manual transmission, but at least you should be able to use the machine to fax at all!
I apologise if the jargon is confusing, just try to go through the process one step at a time and you should be fine.
Hope this helps :)
Chris (ziraffa)
Dec 13, 2008 | Brother IntelliFAX 560 Plain Paper Fax
0009: Error during TX message
Guys,
I got the same problems and then I contacted our PSTN provider and they configured the route. Now it is working fine!
Jul 18, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Fax Canon JX200
is there any error messages coming out from your fax machine.see the error messages first.the paper should run smoothly during sending and receiving process
May 06, 2008 | Canon FAX-JX200
MP830 Canon Faxing problem
Display the fax menu and then select Print Report\List and print the Users Data List. Check the setting of the ECM TX setting. If this is ON turn it OFF. This is the Error Correction Mode setting, probability is the fax you are sending to is not ECM compatible. The MP830 is suppose to automatically send in standard mode if receiving machine is not ECM compatible however I am not sure how well this works. Turn the ECM setting off by displaying the Fax Menu and then select Maintenance\Settings, Device Settings, Fax Settings, TX settings, ECM TX.
Feb 25, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
1,093 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
